IdeaSpark ESP32 w/ CC1101 - TFT LCD Text not Scrolling
UPDATE: I've had a mental lapse and completely missed that IdeaSpark is not an LCD, but a TFT LCD display... hence the use of Adafruit_ST7789. I'm not going to change the original posting, but wanted to note that. I'm not sure what the difference is between TFT and TFT LCD in terms of programming requirements to automatically Scroll UP when the screen is filled and a new line is sent.
Setup is IdeaSpark ESP32 1.9" display and CC1101 connected via HSPI. (LCD is hardwired via VSPI. Was not able to get CC1101 working using VSPI setup with a different CS.)
The code runs fine receiving signals and printing outputs on both Serial and LCD. However, the LCD is not scrolling vertically as new printed lines are sent compared to how it works on a TFT display. This is first time using LCD display.
Would appreciate assistance in figuring this out.
IdeaSpark ESP32 + CC1101 Receive
// These examples are from the Electronics Cookbook by Simon Monk
//https://github.com/LSatan/SmartRC-CC1101-Driver-Lib
// mod by Little_S@tan
#include <ELECHOUSE_CC1101_SRC_DRV.h>
#include <SPI.h>
#include <Adafruit_GFX.h>    // Importing the Adafruit_GFX library
#include <Adafruit_ST7789.h> // Import the Adafruit_ST7789 library
byte buffer[61] = {0};
// // Initialize SPI objects
SPIClass *vspi = NULL;
SPIClass *hspi = NULL;
//------------------------DISPLAY---------------------------------------------
//Define the size of the screen
#define LCD_WIDTH  170
#define LCD_HEIGHT 320
//Define the pins of the ESP32 connected to the LCD
#define LCD_MOSI 23  // SDA Pin on ESP32 D23
#define LCD_SCLK 18  // SCL Pin on ESP32 D18
#define LCD_CS   15  // Chip select control pin on ESP32 D15
#define LCD_DC    2  // Data Command control pin on ESP32 D2
#define LCD_RST   4  // Reset pin (could connect to RST pin) on ESP32 D4
#define LCD_BLK  32  // Black Light Pin on ESP32 D32
//Create the Adafruit_ST7789 object
Adafruit_ST7789 lcd = Adafruit_ST7789(LCD_CS, LCD_DC, LCD_MOSI, LCD_SCLK, LCD_RST);
//ALTERNATE SPI PINOUTS
#define HSPI_MISO 12
#define HSPI_SS 27
#define HSPI_SCLK 14
#define HSPI_MOSI 13
int gdo0 = 26;
//#define URF_MODULE_GDO0 26   // testing only
void setup(){
    // Initialize VSPI with default pins
    vspi = new SPIClass(VSPI);
    vspi->begin();
    // Initialize HSPI with default pins
    hspi = new SPIClass(HSPI);
    hspi->begin();
    lcd.init(LCD_WIDTH, LCD_HEIGHT);
    lcd.setRotation(1);  //The parameters are: 0, 1, 2, 3, representing the rotation of the screen 0°, 90°, 180°, 270°
    lcd.fillScreen(ST77XX_BLACK);
    lcd.setTextColor(ST77XX_WHITE);
    lcd.setTextSize(1);
    Serial.println("Display Initialized");
    lcd.println("Display Initialized");
    ELECHOUSE_cc1101.setSpiPin(HSPI_SCLK, HSPI_MISO, HSPI_MOSI, HSPI_SS);
    if (ELECHOUSE_cc1101.getCC1101()){      // Check the CC1101 Spi connection.
    Serial.println("Connection OK");
        lcd.println("CC1101 Connection OK");
    Serial.println("Connection Error");
        lcd.println("Connection Error");
    ELECHOUSE_cc1101.Init();                // must be set to initialize the cc1101!
    ELECHOUSE_cc1101.setGDO0(gdo0);         // set lib internal gdo pin (gdo0). Gdo2 not use for this example.
    ELECHOUSE_cc1101.setCCMode(1);          // set config for internal transmission mode.
    ELECHOUSE_cc1101.setModulation(0);      // set modulation mode. 0 = 2-FSK, 1 = GFSK, 2 = ASK/OOK, 3 = 4-FSK, 4 = MSK.
    ELECHOUSE_cc1101.setMHZ(433.92);        // Here you can set your basic frequency. The lib calculates the frequency automatically (default = 433.92).The cc1101 can: 300-348 MHZ, 387-464MHZ and 779-928MHZ. Read More info from datasheet.
    ELECHOUSE_cc1101.setDeviation(47.60);   // Set the Frequency deviation in kHz. Value from 1.58 to 380.85. Default is 47.60 kHz.
    ELECHOUSE_cc1101.setChannel(0);         // Set the Channelnumber from 0 to 255. Default is cahnnel 0.
    ELECHOUSE_cc1101.setChsp(199.95);       // The channel spacing is multiplied by the channel number CHAN and added to the base frequency in kHz. Value from 25.39 to 405.45. Default is 199.95 kHz.
    ELECHOUSE_cc1101.setRxBW(812.50);       // Set the Receive Bandwidth in kHz. Value from 58.03 to 812.50. Default is 812.50 kHz.
    ELECHOUSE_cc1101.setDRate(99.97);       // Set the Data Rate in kBaud. Value from 0.02 to 1621.83. Default is 99.97 kBaud!
    ELECHOUSE_cc1101.setPA(10);             // Set TxPower. The following settings are possible depending on the frequency band.  (-30  -20  -15  -10  -6    0    5    7    10   11   12) Default is max!
    ELECHOUSE_cc1101.setSyncMode(2);        // Combined sync-word qualifier mode. 0 = No preamble/sync. 1 = 16 sync word bits detected. 2 = 16/16 sync word bits detected. 3 = 30/32 sync word bits detected. 4 = No preamble/sync, carrier-sense above threshold. 5 = 15/16 + carrier-sense above threshold. 6 = 16/16 + carrier-sense above threshold. 7 = 30/32 + carrier-sense above threshold.
    ELECHOUSE_cc1101.setSyncWord(211, 145); // Set sync word. Must be the same for the transmitter and receiver. (Syncword high, Syncword low)
    ELECHOUSE_cc1101.setAdrChk(0);          // Controls address check configuration of received packages. 0 = No address check. 1 = Address check, no broadcast. 2 = Address check and 0 (0x00) broadcast. 3 = Address check and 0 (0x00) and 255 (0xFF) broadcast.
    ELECHOUSE_cc1101.setAddr(0);            // Address used for packet filtration. Optional broadcast addresses are 0 (0x00) and 255 (0xFF).
    ELECHOUSE_cc1101.setWhiteData(0);       // Turn data whitening on / off. 0 = Whitening off. 1 = Whitening on.
    ELECHOUSE_cc1101.setPktFormat(0);       // Format of RX and TX data. 0 = Normal mode, use FIFOs for RX and TX. 1 = Synchronous serial mode, Data in on GDO0 and data out on either of the GDOx pins. 2 = Random TX mode; sends random data using PN9 generator. Used for test. Works as normal mode, setting 0 (00), in RX. 3 = Asynchronous serial mode, Data in on GDO0 and data out on either of the GDOx pins.
    ELECHOUSE_cc1101.setLengthConfig(1);    // 0 = Fixed packet length mode. 1 = Variable packet length mode. 2 = Infinite packet length mode. 3 = Reserved
    ELECHOUSE_cc1101.setPacketLength(0);    // Indicates the packet length when fixed packet length mode is enabled. If variable packet length mode is used, this value indicates the maximum packet length allowed.
    ELECHOUSE_cc1101.setCrc(1);             // 1 = CRC calculation in TX and CRC check in RX enabled. 0 = CRC disabled for TX and RX.
    ELECHOUSE_cc1101.setCRC_AF(0);          // Enable automatic flush of RX FIFO when CRC is not OK. This requires that only one packet is in the RXIFIFO and that packet length is limited to the RX FIFO size.
    ELECHOUSE_cc1101.setDcFilterOff(0);     // Disable digital DC blocking filter before demodulator. Only for data rates ≤ 250 kBaud The recommended IF frequency changes when the DC blocking is disabled. 1 = Disable (current optimized). 0 = Enable (better sensitivity).
    ELECHOUSE_cc1101.setManchester(0);      // Enables Manchester encoding/decoding. 0 = Disable. 1 = Enable.
    ELECHOUSE_cc1101.setFEC(0);             // Enable Forward Error Correction (FEC) with interleaving for packet payload (Only supported for fixed packet length mode. 0 = Disable. 1 = Enable.
    ELECHOUSE_cc1101.setPRE(0);             // Sets the minimum number of preamble bytes to be transmitted. Values: 0 : 2, 1 : 3, 2 : 4, 3 : 6, 4 : 8, 5 : 12, 6 : 16, 7 : 24
    ELECHOUSE_cc1101.setPQT(0);             // Preamble quality estimator threshold. The preamble quality estimator increases an internal counter by one each time a bit is received that is different from the previous bit, and decreases the counter by 8 each time a bit is received that is the same as the last bit. A threshold of 4∙PQT for this counter is used to gate sync word detection. When PQT=0 a sync word is always accepted.
    ELECHOUSE_cc1101.setAppendStatus(0);    // When enabled, two status bytes will be appended to the payload of the packet. The status bytes contain RSSI and LQI values, as well as CRC OK.
    Serial.println("Rx Mode");
void loop(){
   //Checks whether something has been received.
  if (ELECHOUSE_cc1101.CheckReceiveFlag()){
    //CRC Check. If "setCrc(false)" crc returns always OK!
    if (ELECHOUSE_cc1101.CheckCRC()){
    //Rssi Level in dBm
      Serial.print("Rssi: ");
      Serial.println(ELECHOUSE_cc1101.getRssi());
        lcd.print("Rssi: ");
        lcd.println(ELECHOUSE_cc1101.getRssi());
    //Link Quality Indicator
      Serial.print("LQI: ");
      Serial.println(ELECHOUSE_cc1101.getLqi());
        lcd.print("LQI: ");
        lcd.println(ELECHOUSE_cc1101.getLqi());
    //Get received Data and calculate length
      int len = ELECHOUSE_cc1101.ReceiveData(buffer);
      buffer[len] = '\0';
    //Print received in char format.
      Serial.println((char *) buffer);
        lcd.println((char *) buffer);
    //Print received in bytes format.
      for (int i = 0; i<len; i++){
        Serial.print(buffer[i]);
        Serial.print(",");
        lcd.print(buffer[i]);
        lcd.print(",");
        lcd.println();
IdeaSpark ESP32 + CC1101 Transmit
// Define SPI pins
#define SCK_PIN 18
#define SS_PIN 5
#define MISO_PIN 19
#define MOSI_PIN 23
int gdo0;
byte one_byte[8][1]={{0x01},{0x02},{0x04},{0x08},{0x10},{0x20},{0x40},{0x80}};
int i=0;
byte transmitt_byte[11] = {72,101,108,108,111,32,87,111,114,108,100};
char *transmitt_char = "Hello World";
    ELECHOUSE_cc1101.setSpiPin(SCK_PIN, MISO_PIN, MOSI_PIN, SS_PIN);
    #ifdef ESP32
    gdo0 = 2;  // for esp32! GDO0 on GPIO pin 2.
    #elif ESP8266
    gdo0 = 5;  // for esp8266! GDO0 on pin 5 = D1.
    #else
    gdo0 = 6;  // for Arduino! GDO0 on pin 6.
    #endif
    }else{
    Serial.println("Tx Mode");
//4 different methods to send data
//Transmitt "Hello World" from byte format.
ELECHOUSE_cc1101.SendData(transmitt_byte, 11);
    Serial.println("byte Mode");
delay(1500);
//Transmitt "Hello World" from char format.
ELECHOUSE_cc1101.SendData(transmitt_char);
    Serial.println("char Mode");
delay(1500);
//Transmitt "Hello World" from char format directly.
ELECHOUSE_cc1101.SendData("Hello World");
    Serial.println("char direct Mode");
//Transmitt for 2FSK
ELECHOUSE_cc1101.SendData(one_byte[i], 1, 100);
    delay(1500);
    i=(i+1)%8;
    Serial.println("2FSK");
Does new data overwrite old data, using the full screen width (carriage return with no line feed)?
Does new data append to the end of old data (no CR, no LF)?
Describe how it works on a TFT.
The LCD prints the first full screen properly then nothing more happens. However, the Serial printing continues and the signal output is verified using rtl_SDR receiver.
The TFT worked fine using the a default Adafruit_GFX print commands... the screen automatically scrolls upward as new print commands are sent... if I recall correctly
What are the compile results? (memory usage)
Sounds like the LCD is printing to the end of its buffer... and beyond... unseen.
One method: Print text, go to top of LCD, print text starting from "startline++", repeat until all text scrolls off.
Here's the compilation results using Partition Scheme: NO OTA (1MB APP/3MB FATFS):
(Plan to eventually create a data collection process to store in a FAT file)
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4888
load:0x40078000,len:16516
load:0x40080400,len:4
load:0x40080404,len:3476
entry 0x400805b4
Display Initialized
Connection OK
Rx Mode
ESP Free Heep: 333308
ESP Free Flash: 16777216
