Hi
I have a Thule AV100 that is able to control a Thule PA350B trough a ethernet cable (RJ45 plug in each end).
Measuring the output from the AV100 shows:
3.3V on the RJ45 pin 1 and 2 over 8 (gnd)
9.8V on the RJ45 pin 5 and 7 over 8 (gnd)
0V on the RJ45 pin 3, 4 and 6 over 8 (gnd)
It seems like pin 1 is data and pin 2 is clock.
How may I observe what signal is sendt from the AV100 to the PA350B to control it?
And how may I use the same signals to control the PA350B from an aurdino instead of from the AV100?
It appears that pins 1 and 2 would be used for communication between the devices. Get a logic analyzer and connect to pins 1, 2 and 8 and see what the signals look like. A $10-$15 USB 24MHz/8 channel logic analyzer (use that for the search term) should be fine. Available from the usual sources or Amazon or ebay.
Do you have any documentation that tells you the control information that uses the bi-directional clock and data on pins 1 and 2 are duplicated on the RS-232 connections? That would be critical information if you want to observe the signals/message data.
the simpliest way, as it was already mentioned is to use cheap 8channel logic analyzer. So you can identify clock & data pins. Once identified, things get much simplier :))
