I have a 4 digit LED display, I can individually set each digit to an ascii character, but what I want to do is write a function to simply write a 4 digit integer straight to the display.
This is what I’ve come up with…
void FourDigitLed::writeInt(int val)
int tho = val/1000;
int hun = (val-(tho*1000)) /100;
int ten = (val-(tho*1000)-(hun*100) ) / 10;
int uni = val - (tho*1000)-(hun*100) - (ten*10);
//Serial.print("Val = <");Serial.print(val);Serial.print("> OR ...<");Serial.print(tho);Serial.print(hun);Serial.print(ten);Serial.print(uni);Serial.println(">");
_alpha4.writeDigitAscii(0, (char)(tho+48)); // Thousands
_alpha4.writeDigitAscii(1, (char)(hun+48)); // Hundreds
_alpha4.writeDigitAscii(2, (char)(ten+48)); // Tens
_alpha4.writeDigitAscii(3, (char)(uni+48)); // Units
_alpha4.writeDisplay();
The good news is that it seems to work fine, but I can’t help feeling that this is using a hammer to crack an egg, there’s got to be a simpler one-line solution isn’t there?
Yes, the division and modulo operators are very expensive on the Arduino. If you have to run this in a fast loop, like controlling a motor, then the time spent just dividing by 1000 becomes significant.
The correct 'library' solution is to use the itoa() function that's part of the standard C libraries. Unfortunately the Arduino reference doesn't give you any good launchpad to get into that documentation, despite it all being included in the GCC distribution. The best online reference is here: <cstdlib> (stdlib.h) - C++ Reference
Often I just end up rolling my own solution, since I want to output the characters individually. A series of subtractions is faster than division:
//note val must be positive and less than 9999
//put some checks in here and show different outputs for those errors
const int ZERO = 48;
char digit;
for(digit = ZERO; val > 1000; digit++) {
val-=1000;
_alpha4.writeDigitAscii(0, digit); // Thousands
for(digit = ZERO; val > 100; digit++) {
val-=100;
_alpha4.writeDigitAscii(1, digit); // hundreds
for(digit = ZERO; val > 10; digit++) {
val-=10;
_alpha4.writeDigitAscii(2, digit); // tens
for(digit = ZERO; val > 1; digit++) {
val-=1;
_alpha4.writeDigitAscii(3, digit); // units
}[/code
Would itoa() really work if you need it to be zero-padded?
For ease of extraction base-10 digits, I tend to use binary-coded decimal a lot.
What is binary-coded decimal? Jones on BCD Arithmetic
