Identifying Infrared sensors in a program
I tried switching code from using a PING))) to using IR sensors. I'm new to all of this, so I was just wondering if I have to instruct the program how to use the IR sensors, or if everything that's been used for the PING))) will be the same.
Here is the code (with the right source) but with my edits.
/*MAEP 2.0 Navigation
by Noah Moroze, aka GeneralGeek
This code has been released under a Attribution-NonCommercial-ShareAlike license, more info at About The Licenses - Creative Commons
PING))) code by David A. Mellis and Tom Igoe http://www.arduino.cc/en/Tutorial/Ping
#include <Servo.h> //include Servo library
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int irreceiverPin = 7;
const int irPin = 0; //Sharp infrared sensor pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
rightMotor.attach(11);
leftMotor.attach(10);
panMotor.attach(6); //attach motors to proper pins
panMotor.write(90); //set ir receiver pan to center
int distanceFwd = irreceiver();
if (distanceFwd>dangerThresh) //if path is clear
leftMotor.write(LForward);
rightMotor.write(RForward); //move forward
else //if path is blocked
leftMotor.write(LNeutral);
rightMotor.write(RNeutral);
panMotor.write(0);
rightDistance = irreceiver(); //scan to the right
panMotor.write(180);
delay(700);
leftDistance = irreceiver(); //scan to the left
panMotor.write(90); //return to center
delay(100);
compareDistance();
void compareDistance()
if (leftDistance>rightDistance) //if left is less obstructed
leftMotor.write(LBackward);
rightMotor.write(RForward); //turn left
else if (rightDistance>leftDistance) //if right is less obstructed
rightMotor.write(RBackward); //turn right
else //if they are equally obstructed
rightMotor.write(RBackward); //turn 180 degrees
long irreceiver()
// Send out IR waves/ signal pulse
pinMode(irreceiverPin, OUTPUT);
digitalWrite(irreceiverPin, LOW);
delayMicroseconds(2);
digitalWrite(irreceiverPin, HIGH);
delayMicroseconds(5);
//Get duration it takes to receive echo
pinMode(irreceiverPin, INPUT);
duration = pulseIn(irreceiverPin, HIGH);
//Convert duration into distance
return duration / 29 / 2;
What sort of IR sensor?
I don't know any that rely on time-of-flight.
Please remember to use code tags when posting code
You have to instruct the program to do anything you want to do.
No.
Consider the difference in speed of sound in air and light in air. Consider how long it takes for light to travel 1 meter and then think you have a processor that can not do instructions faster than 16000000 per second. Is that fast enough?
