Hello! i got this Arduino Due clone, called Iduino Due and i can't get it to show up as connected on my windows 10 pc.
I think its a driver relateed issue because i get the yellow icon on the device manager when i try to manually set the "arduino due-programming port" drivers under the lpt-com ports.
Hmm the only arduino that i got working uses that big USB type 2, but this board comes with a small port that i can't identify yet. Anyhow, i will keep trying different cables!
I can verify it was the cable, now i just uploaded the blink and the board is working.
I was'nt aware of the difference between "charge only" cables and "data transfer" ones, now i know that the charge only are cheaper to manufacture because they come with two less wires!
And yes, once i used the correct cable, the board was recognized immediately. It uses a "Micro-B" type... that needs to be a data transfer cable
