So in my setup() I am starting my SD and then checking to see if it was started correctly. If it was started correctly I print "initialization done." on an LCD and if not started correctly I print to the LCD "initialization failed!". The problem is when I check whether SD.begin(10) returns true or false I can no longer print to the LCD.
The if statement works fine if I use some other parameters. But when I use SD.begin the lcd.print statements no longer work, and I have no idea what the problem is.
#include <SD.h>
#include <Wire.h>
#include "R8025.h"
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
File temperature_File;
const int temp_monitor1=0;
const int temp_monitor2=1;
const int yellow_light=9;
const int red_light=6;
const int good_button=8;
const int bad_button=7;
int temp1,temp2;
int good_sd_initialization =0;
/******* The error variable will be used to identify and resolve errors ******
******** Error = 0 Then there is nothing wrong ******
******** Error = 1 Then the SD card is missing/can not be read ******
******** Error = 2 Can not connect to other xbeee(not sure how to do) ******
******** Error = 3 Temperature sensors have problems ******/
int error=0;
/**** Variables for the RTC ****/
R8025 RTC;
DateTime now;//used to get the time when we need to print it
/****variables for good button debounce*****/
int good_lastButtonState = LOW; // the previous reading from the input pin
long good_lastDebounceTime = 0; // the last time the output pin was toggled
long good_debounceDelay = 150; // the debounce time; increase if the output flickers
int good_buttonState = 0; // variable for reading the pushbutton status
/****variables for bad button debounce*****/
int bad_lastButtonState = LOW; // the previous reading from the input pin
long bad_lastDebounceTime = 0; // the last time the output pin was toggled
long bad_debounceDelay = 150; // the debounce time; increase if the output flickers
int bad_buttonState = 0; // variable for reading the pushbutton status
/*** LCD ****/
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/***Setting up all the pins***/
Wire.begin();
Serial.begin(19200);
pinMode(yellow_light,OUTPUT);
pinMode(red_light,OUTPUT);
pinMode(good_button,INPUT);
pinMode(bad_button, INPUT);
pinMode(10, OUTPUT);
/***Checking if SD card is available***/
lcd.begin(16, 2);
lcd.setCursor(0, 0);
Serial.print("Initializing SD card...");
lcd.clear();
lcd.print("Initializing SD ");
lcd.setCursor(0,1);
lcd.print("card ...........");
delay(3000);
lcd.clear();
if (!SD.begin(10)) {
Serial.println("initialization failed!");
lcd.print("initialization");
lcd.setCursor(0, 1);
lcd.print("failed!");
delay(5000);
digitalWrite(red_light,HIGH);
else{
Serial.println("initialization done.");
lcd.print("done.");
delay(5000);
digitalWrite(yellow_light,HIGH);
/* switch(SD.begin(10)){
case false:
delay(5000);
case true:
lcd.print("done.");
delay(5000);
lcd.clear();
/*** Setting up the RTC ***/
RTC.begin();
RTC.adjust(DateTime(__DATE__, __TIME__)); //sets the date and time to the time file was compiled based on computer clock
//note no idea why RTC.begin() is needed twice but without them it does not work
//code to be added still
You can't use the SPI pins for your LCD because the SD-Card is a SPI device. So when you start using the SD-Card, communication with the LCD is no longer possible.
noob here..wanting to jump on the band wagon here, real quick... to learn/understand a bit more about the SPI bus.
can you NOT have more than one device on the SPI bus at a time? I thought that was the point?
I have read tings like making sure the SS_pin (hardware) is set to output first..to allow more than one device to be on the same SPI bus.. but have different CS pins?
Is this specific to the SD device? I sorta ran into the same problem with having the uSD card and DAC on the same SPI bus (sharing the same, 11, 12, 13 pins..but each having different/separate CS pins, 10 & 9 respectively)
but the WaveHC library I had planned on using doesnt seem to work that way.. and use a 'bit bang' method to keep reading info form the card..and pass to the DAC..
so I wanted to jump in here and learn a bit more to understand how it works..or should work..
You can have more than one SPI device on the SPI bus. The LCD is not an SPI device. It doesn't belong on the SPI bus.
