IF and ELSE statement
I have the below piece of code that I have to control and monitor LIGHTS and temperature. I send specific SMS's to the GSM SIM900 shield which arduino then reads to control and monitor the lights.
#include <SoftwareSerial.h>
#include <EEPROM.h>
SoftwareSerial SIM900(2,3); // RX, TX
int pin8 = 8;
int led13 = 13;
char buffer[9]; // eight char plus null terminator
char secret_code[] = "20!4#a1";
char secret_code1[] = "20!4#a0";
char secret_code2[] = "20!4#aS";
char secret_code3[] = "20!4#gt";
char incoming_char=0;
byte buffer_pos=0;
float temperature;
byte threshold;
int addr = 0;
/*-----( Declare Constants )-----*/
#define RELAY_ON 1
#define RELAY_OFF 0
/*-----( Declare variables )-----*/
#define Relay_1  8  // Arduino Digital I/O pin number
#define Relay_2  7
#define Relay_3  6
#define Relay_4  5
  pinMode(pin8, OUTPUT);
  pinMode(led13, OUTPUT);
  digitalWrite(led13, LOW);
  digitalWrite(pin8, LOW);  // Set led to LOW
    pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
  Serial.begin(19200); // set the baud rate
  SIM900.begin(19200); // for GSM shield
  delay(20000);  // give time to log on to network.
  SIM900.print("ATE0\r");
  SIM900.print("AT+CMGF=1\r");  // set SMS mode to text
  delay(100);
  SIM900.println("AT+CNMI=2,2,0,0,0\r");
  delay(100);
  Serial.println("Finished Setup Section");
// SENDING AN SMS WITH THE LIGHT STATUS//
void sendSMS(byte led_status)
  SIM900.print("AT+CMGF=1\r");                     // AT command to send SMS message
  SIM900.println("AT + CMGS = \"+277XXXXX\"");  // recipient's mobile number, in international format
  if (led_status==0)
    SIM900.println( " LIGHT STATUS: OFF");
    SIM900.println( " LIGHT STATUS: ON");
  SIM900.println((char)26);                        // End AT command with a ^Z, ASCII code 26
  SIM900.println();
  Serial.println("Message sent");
  delay(5000);     // give module time to send SMS
// SENDING SMS WHEN TEMPERATURE IS ABOVE THE DEFINED THRESHOLD//
void sendSMSTemp()
  SIM900.print( " WARNING TEMPERATURE IS: ");
  SIM900.print(temperature);
  Serial.println(temperature);
  SIM900.println( " degree Celcius");
  SIM900.println();
// SENDING SMS WITH CURRENT TEMPERATURE READINGS//
void sendSMSTempCurrent()
  SIM900.print( " CURRENT TEMPERATURE IS: ");
  SIM900.println();
// SENDING SMS IF WRONG TEXT IS SENT //
void sendSMSWrongText()
  SIM900.println("Sorry! You have sent incorrect SMS code.");        // message to send
  SIM900.println();
// READING THE TEMPERATURE //
void readtemp()
  int val = analogRead(0);
  float voltage = val * (4.0  /1023);  // compiler can optimize the constant part
  temperature = voltage * 100;  // 0.01V = 1C
  EEPROM.write(addr, 30);    // writing into EEPROM
  threshold = EEPROM.read(addr);  // reading EEPROM value
  Serial.print("Current Temp: ");
  Serial.print(temperature, 2); // Reading the temperature to 2 decimal point
  Serial.println("C");               // ALT-0176 => °
  if (temperature >= threshold)
    sendSMSTemp();
    do {
    while (1);
    delay(5000);              // wait for 5 second
    sendSMSTempCurrent();
// MAIN LOOP //
  if (SIM900.available()>0)
    Serial.println("Reading incoming data");
    incoming_char=SIM900.read();
    if (incoming_char=='?')
      Serial.println("Got a ?");
      delay(100);
      buffer_pos=0;
      while (SIM900.available())
        delay(100);
        buffer[buffer_pos]=incoming_char;
        buffer_pos++;
        if (buffer_pos==7) // Already incremented
          //Print it out
          buffer[buffer_pos]='\0';
          Serial.write(buffer);
          if (strcmp(buffer,secret_code)==0)
            Serial.println("It's a match!");
            digitalWrite(pin8, HIGH);
            int led_status=digitalRead(pin8);
            Serial.print ("LED status = ");
            Serial.println(led_status);  // prints status on serial terminal
            sendSMS(led_status);
            delay(1000);              // wait for a second
          buffer_pos=0;
          if (strcmp(buffer,secret_code1)==0)
          buffer_pos=0;
          if (strcmp(buffer,secret_code2)==0)
          buffer_pos=0;
          if (strcmp(buffer,secret_code3)==0)
            readtemp();
            sendSMSWrongText();
          buffer_pos=0;
I then wanted to say if the SMS sent is not matched (wrong code is sent), arduino should send an SMS to notify user. So i then added the ELSE function in my code as below:
            sendSMSWrongText();
My PROBLEM: Even when the SMS sent has the correct code, the ELSE function runs repeatedly ::slight_smile: . How do I make sure that the ELSE function will only run when the a match is NOT found.
Your assistance will be highly appreciated
It's hard for me to figure out where you inserted the if clause. I suggest you put it in your code, mark it with a comment so it stands out, and repost the relevant section of code.
Hint:-
What happens when you receive nothing?
Hi Econjack,
My IF statements are included in the void loop() as below and the ELSE is at the bottom:
      delay(100);
      buffer_pos=0;
        delay(100);
        buffer_pos++;
          //Print it out
          buffer_pos=0;
          buffer_pos=0;
          buffer_pos=0;
            readtemp();
            sendSMSWrongText();
          buffer_pos=0;
@Grumpy_Mike, do you mean what happens when the SMS is blank?
No I mean what happens when there is nothing to receive?
