if() and for() structures
Beating my head against a desk trying to figure out this really simple bit of #arduino programming.
The objective I am trying to meet is to write a program to print "Hello" fifty times on your computer twice. Use if() structure once, and for() structure once.
I have this code below which can print a numbered list of 50 "hello"s, but not sure how to end it after two loops using a for loop, or if I'm just going the wrong way to start.
int x = 1; void setup() { Serial.begin(9600); delay(2000); }
void loop() { Serial.println(x); Serial.println("Hello"); delay(100); x++; if (x>50) {delay(1000); x=1;}; }
Am I going the wrong direction? How would you do this simple task?
   for(int i=0; i<2; i++)
      for(int j=0; j<50; j++)
         Serial.println("Yo");
You could do it in loop() instead, and use a counter.
   static int i = 0;
   if(i < 2)
      i++;
Hope we get a good grade.
Heh, not a real homework assignment, just a practice problem :)
Still getting a hang of this coding thing. Took this class as a senior elective - I am a mechanical engineer with zero coding and the bare minimum of basic ECE... a whole new world this arduino playground is...
Loop will run indefinitely. If you want it to stop at 50, try:
  If ( x++ <= 50 ) {
    Serial.println( x );
    Serial.println( "Hello" );
    delay( 100 );
Oh and a big THANK YOU to PaulS as well, since I seemed to have forgotten my manners and left out a thank you in the first reply!
If you want a sketch to perform a task and then stop you could also put the code inside setup() and leave loop() totally void:
loop() { }
