If block is getting executed even if the "if" conditions are not met
My question is why the if block is getting executed even if the conditions are not met , in this case I'm using esp8266(Nodemcu) and when i push the buttons it gets increment and decrement like I supposed to be but the values goes above 23(24) and then im unable to go inside if block as x<=23 is false , is it suppose to happen ?? logically it should not right ??.........Btw this is test code, I'm working on small project ,I thought I had some problem with my entire code so I snipped this piece to test and it doesn't work here also :smiling_face_with_tear:
unsigned int x=5;
  pinMode(D3, INPUT_PULLUP);
  pinMode(D4, INPUT_PULLUP);
 if (digitalRead(D4) == LOW && x >= 2 && x <= 23) {
    x++;
  if (digitalRead(D3) == LOW && x >= 2 && x <= 23) {
    x--;
    Serial.println(x);
Let’s assume x is 23 and D4 is LOW.
The next time around, x will go to 24 then things will lock up
Thanks for replying so fast , I got what u said , but thats exactly my problem isn't there any way to remove this lockup , i just want the value to be between 2-23, I thought of putting another if that will set the value to 23 but then the values will continuously bounce btwn 23 and 24
    x++;
    if(x > 23)
      x = 23;
etc. . .
Thanks man , helped me a lot ,sry it was a silly question for me to post without looking at my own code , I used this same technique elsewhere in the original code , I guess the original code is too big and messy to understand by my self ,thanks again
Hello harsh001
Take a view here too:
Have a nice day and enjoy programming in C++ and learning.
Errors and omissions excepted.
Slightly simpler; don't increment if the value is 23 and don't decrement if the value is 2:
  if (digitalRead(D4) == LOW && x < 23) {
    x++;
  if (digitalRead(D3) == LOW && x > 2) {
    x--;
