I am making a UV disinfectant BOX using OSRAM 254nm wavelength light.
Intended operation,
When the start button is pressed and the reed switch ON.
2 relays should turn ON for 120sec I.e 2min.
If the start button is pressed again during the count down, another 60sec should be added to the down count. (if the start button is pressed twice 120sec should be added)
And if the reed switch goes OFF in between the down count, both the relay should be turned off.
I have made an effort to put up a basic code, I need the forums to help to complete the code part
as I have a good understanding of hardware.
This is initial code I have written. It works but i know it can be written well and it does not have No 3) function.
#include <stdio.h>
#include <Wire.h> // Library for I2C
#include <LiquidCrystal_I2C.h> // Library for LCD
const long interval = 500; // Interval at which buzzer beeps
// Input and output Pins
int ButtonState = 2; // Interrupt input Pin D2 on Nano for Button switch
int ReedSwitch = 3; // Interrupt input Pin D3 on Nano for magnetic reed switch
int FanRelay = 7; // Output Pin D7 on Nano for fan relay
int LightRelay = 8; // Output pin D8 on Nano for light relay
int BuzzerPin = 6; // Output pin D6 on Nano for Buzzer
int Seconds;
int logic1 = 0;
int logic2 = 0;
int BuzzerState = LOW;
LiquidCrystal_I2C lcd(0x27, 16, 2);
pinMode(FanRelay, OUTPUT);
pinMode(LightRelay, OUTPUT);
pinMode(BuzzerPin, OUTPUT);
pinMode(ButtonState, INPUT);
pinMode(ReedSwitch, INPUT);
digitalWrite(FanRelay, HIGH);
digitalWrite(LightRelay, HIGH);
digitalWrite(BuzzerPin, LOW);
lcd.init();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("UV SANITIZER BOX");
delay(3000);
void splashscreen()
lcd.clear();
lcd.print("2 Min SANITATION");
lcd.setCursor(0, 1);
lcd.print("* Press Start *");
delay(100);
void DisplayTime()
lcd.clear();
lcd.print(" Time Remaining");
lcd.print("Seconds - ");
lcd.setCursor(10, 1);
lcd.print(Seconds);
void DisplayInterrupt()
lcd.clear();
lcd.print("UV SANITATION");
lcd.print("Interrupted!!!!!");
delay(3000);
void DisplayFinish()
lcd.clear();
lcd.print("****COMPLETE****");
delay(5000);
splashscreen();
logic1 = digitalRead(ButtonState);
logic2 = digitalRead(ReedSwitch);
if (logic1 == 1 && logic2 == 1 )
for (int Countdown = 240; Countdown >= 0; Countdown --)
digitalWrite(LightRelay, LOW);
digitalWrite(FanRelay, LOW);
tone(BuzzerPin, 500);
Seconds = (Countdown / 2);
DisplayTime();
if (logic2 == 0 )
DisplayInterrupt();
DisplayFinish();
else {
I want to use MILLIS() for the delay.
In the below code “if ((logic1 == 1) && (logic2 == 1))” works fine only when Both logic1 & logic2 are HIGH. when logic2 is LOW and logic1 is HIGH the relay turns on for the duration logic1 is HIGH.
offat = millis()+5000;
Serial.print(offat);
if (digitalRead(FanRelay) == HIGH)
if((millis() >= offat) || (logic2 == LOW))
Thank you
