If condition problem =S / Please Help, Urgent
i write a code that switch pin 13 on and off by sending 1 and 2
i put an if condition to show a error message when another value other than 1 or 2 is received
the problem when i open serial monitor, it keep on displaying the error message, without even writing any number yet =S
what did i do wrong? the code is written below
char val; // variable to receive data from the serial port int f = 13;
void setup() { pinMode(f = 13, OUTPUT); // pin 13 as OUTPUT Serial.begin(9600); // start serial communication at 9600bps }
void loop() { if( Serial.available() ) {;} // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == '1' ) { // if '1' was received, led 13 is off digitalWrite(f, LOW); // turn Off pin 13 off delay(1000); // waits for a second Serial.println("13 off"); }
if( val == '2' ) { // if '2' was received, led 13 is on digitalWrite(f = 13, HIGH); // turn ON pin 13 on delay(1000); // waits for a second Serial.println("13 on"); }
if( val != '1' || val != '2' ) { Serial.println("Error, Please enter the correct number"); } }
if( Serial.available() ) {;} // if data is available to read No you don't do it like this, you only read when serial data is available. That line of code does nothing.
int f = 13;
  if( Serial.available() ) {       // if data is available to read
  } // end of if( Serial.available()
er I'm sure I just saw this in another thread?!?
one posting is enough
This is the right place please remove the other post.
Thnks alot for reply :)
w yes i posted it in another thread then i realized that this is right place to ask, other post is deleted :)
Thanks
I think the logic is screwed on this line:-
if( val != ‘1’ || val != ‘2’ )
If val is equal to 2 it will not be equal to one and will pass the condition.
So what ever value you use it will report an error.
You mean
if( !( val == ‘1’ || val == ‘2’ ) ) {
yes that's where the error is XD
i tried it and it worked :)
Thnks alot for ur help :)
so glad I took the time to reply to the other post then :(
