So basically I want it to turnright first and then follow the line but bot conditions are true at the start do it just follows the line.... is there any way I can do that ?
Well so basically what i want is say we have this code :
if (sensor3==LOW){turnRight();} //the first time sensor3 becomes low it turnsright and the when it becomes
// low again it follows the line
if (sensor3==LOW){followline();}
but when i try to do it using a variable and incrementing it.... the variable gets incremented random numbers or time ... so that's not viable
Basically what I want to say is Don’t post snippets (Snippets R Us!)
Post full code. We have no idea what sensor3 is, nor how things are wired, powered etc...
Provide details, that’s where the devil always hide.
And if you have code that only tracks pin state and not pin state change, then remember the arduino is running at 16mhz... the loop will execute likely thousands times per second...
Which variable ?
Where is it declared ?
What type of variable is it ?
What is it initial value ?
Where is it incremented ?
How is it incremented ?
By how much is it incremented ?
Is it ever decremented ?
If so, where ?
If so, by how much ?
You mention incrementing a variable but the code tests for equality with LOW. That does not make any sense
#include <Servo.h> // Include servo library
Servo servoLeft; // Declare left and right servos
Servo servoRight;
int button=2;
int led=11;
int d3=3;
int d4=4;
int d5=5;
int d6=6;
int d7=7;
int s1=0;
int s13=0;
int s53=0;
int s2=0;
int s3=0;
int s4=0;
int s5=0;
void setup() // Built-in initialization block
pinMode( button, INPUT_PULLUP);
pinMode(led, OUTPUT);
pinMode( d7, INPUT); // Set right whisker pin to input
pinMode( d6, INPUT);
pinMode( d5, INPUT); // Set right whisker pin to input
pinMode( d4, INPUT);
pinMode( d3, INPUT);
servoLeft.writeMicroseconds(1480); // Left wheel counterclockwise
servoRight.writeMicroseconds(1472);
servoLeft.attach(12); // Attach left signal to P12
servoRight.attach(13); // Attach right signal to P13
//disableServos(); // Stay still indefinitely
void loop() // Main loop auto-repeats
int sensor1 = digitalRead(d7); //Rightmost
int sensor2 = digitalRead(d6);
int sensor3 = digitalRead(d5); //middle
int sensor4 = digitalRead(d4);
int sensor5 = digitalRead(d3); //Lefttmost
//followline(sensor1,sensor2,sensor3,sensor4,sensor5);
//forward();delay(2000);
if(sensor1==LOW && sensor3==LOW){ ++s13;}
//if(sensor2==LOW){ ++s2;}
if(sensor3==LOW && sensor5==LOW){ ++s53;}
if(sensor3==LOW){ ++s3;}
if(sensor5==LOW){ ++s5;}
//forward(2000);turnLeft(1000);forward(4000);turnRight(1000);disableServos();
//disableServos();
// if(s53==0){turnRight();}
//{ followline(sensor1,sensor2,sensor3,sensor4,sensor5);}
//turnRight();
//if(s5==0){turnRight();}
//if(s5!=0 && s3!=0){followline(sensor1,sensor2,sensor3,sensor4,sensor5);}
formatPrint("s5=",s5);
formatPrint("s4=",s13);
formatPrint("s3=",s3);
formatPrint("s2=",s53);
formatPrint("s1=",s1);
int buttonState = digitalRead(button);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(led, HIGH);
// turn LED off:
digitalWrite(led, LOW);
// delay(100);
void followline(int ss1,int ss2,int ss3,int ss4,int ss5)
if(ss2==LOW){turnRight();} //--->line follower segment begins
if(ss4==LOW) {turnLeft();}
if(ss2==LOW && ss3==LOW ){turnRight();}
if(ss4==LOW && ss3==LOW ){turnLeft();}
if(ss3==LOW) {forward();}
void forward() // forward function
servoLeft.writeMicroseconds(1700); // Left wheel counterclockwise
servoRight.writeMicroseconds(1300); }
// Right wheel clockwise
//delay(time); // Maneuver for time ms
void turnLeft() // Left turn function
servoLeft.writeMicroseconds(1300); // Left wheel clockwise
servoRight.writeMicroseconds(1300); // Right wheel clockwise
void turnRight() // Right turn function
servoRight.writeMicroseconds(1700); // Right wheel counterclockwise
// delay(time); // Maneuver for time ms
void backward() // backward function
void formatPrint( char *leftStr, int MyVar1){
Serial.println (leftStr);
Serial.println (MyVar1);
void stay() // Right turn function
servoRight.writeMicroseconds(1472); // Right wheel counterclockwise
void disableServos() // Halt servo signals
servoLeft.detach(); // Stop sending servo signals
servoRight.detach();
So what I understood from pin state change is that it increments only when the state of pin is changed from high to low or low to high....So that might work....could you please tell me how i can code that and use it with my five sensors? So that the counter only increments when the pin state of the sensors changes.
Thank for posting the code, but it is almost impossible to understand due to the cryptic and anonymous variable names used and I don't have the patience to decipher it at the moment.
For instance, what is the point of having a variable named d3 when it holds a value of 3. It would be better named something like leftSensorPin. To compound things, when you read its state you put it in another anonymous variable named sensor5
Please do us and yourself a favour by giving variables meaningful names so that reading the code is more like reading a sentence
Yes that code was working fine for the line following task ... Now I am using that line follower to implement grid navigation.
So I changed the variable name(or at least commented to describe it) for better understanding.
I implemented the state change counter and it works fine (i checked on serial monitor).
Now everything works as it should. Thanks for suggesting the pin state change.....Also if someone knows any grid navigation algorithms and could share a link to them , I will really appreciate it.
Please post your revised code as there may be other changes that it would benefit from, either in its operation, making it easier to understand or both
