if delay between button press
Hello,
I want to build a morse to text convert, where I can input the morse signals with a button press and display the text on a 7-segment display. I have already figured out the button to morse signal operation, but now I whant to detect if there is a space between the characters. This would happen when I pause between the morse symbols. So the code would have to check how much time passed between every button press, and if it crosses a certain threshold it would make a space between the morse characters.
I hope my problem is understandable and you can help me. :wink:
Best regards, Lorenz
Welcome,
When button is released, store the value of millis() in a variable
When button is pressed again, compare this variable with the actual value of millis():
if ( millis() - buttonReleasedMillis > 1000 ) // if time between previous button release and actual button press is greater than one second
ok, I have to say I am completely new to millis. I don't know how I can save the millis in a variable, and how to set up the buttonReleasedMilli. sorry for my stupid question and thanks for your quick answer ;)
unsigned long timeNow = millis();
so I put your information int the for me only sensible order together... when I upload it I get an error message.
int button = 2
unsigned long buttonPress = millis();
pinMode (button, INPUT_PULLUP);
if(button == LOW){
if ( millis() - buttonPress > 1000 ){
  Serial.println("space");
sorry for probably annoying every one :confused:
button has the value 2.
LOW has the value zero
They are never, ever going to be equal.
Try a “digitalRead”
int button = 2
Need a semi-colon
The demo Several Things at a Time illustrates the use of millis() to manage timing. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
