else if (right=left=200) //if right = left = 200
will the above code work ?
Yes, but it will not do what you obviously think it will do. Namely:
else if (right == 200 && left == 200) {...
Thanks. ![]()
This little program illustrates the problem:
int right, left;
right = 10;
left = 200;
if (right == 50) {
Serial.println("First expression");
if (right = left = 0) { // Note: set to zero
Serial.print("right = ");
Serial.print(right);
Serial.print(" left = ");
Serial.println(left);
If you assign any non-zero value to left and right, the second if expression evaluates to logic true. However, set them to zero and it evaluates to logic false and the if block is skipped. As aarg points out, this is probably not what you wanted.
