I have a IR sensor which supplies some voltage when no object is detected, and 0V if something is at 15cm or closer. My aim is to have a LED light up when something is detected.
I believe I can achieve this by:
reading the input from the analog pin to which sensor is connected
if sensor value less than "benchmark" - light the LED
2bis. if sensor value is more than "benchmark" - turn the LED off
display value on serial monitor (when no object detected)
3bis. display "sensor triggered" when value under benchmark and LED on
Now, bear with me, because I am no code wizard and this is where I need your help:
int sensor=0; // assign analog pin zero to sensor
int sensorValue=0; //
int ledPin=2; // assign digital pin two to LED
serial.begin(9600);
pinMode(ledPin, OUTPUT); // are these really necessary?
pinMode(sensor, INPUT);
sensor=analogRead(sensorValue); // to display on serial monitor values from sensor
serial.println(sensor);
delay(100);
I would like you to enlighten me on the use of if/else. I have tried this:
The term is threshold.
sensorValue = analogRead(sensorPin); // to display on serial monitor values from sensor
Serial.println(sensorValue);
if(sensorValue > 150)
// There is something there
Your design specification can be turned into code like this:
const int SENSOR_PIN = A0;
const int LED_PIN = 2;
const int BENCHMARK = 100;
pinMode(LED_PIN, OUTPUT);
// No pinMode() needed for analogRead()
// 1. reading the input from the analog pin to which sensor is connected
int input = analogRead(SENSOR_PIN);
// 2. if sensor value less than "benchmark" - light the LED
if (input < BENCHMARK)
digitalWrite(LED_PIN, HIGH);
//2bis. if sensor value is more than "benchmark" - turn the LED off
if (input > BENCHMARK)
digitalWrite(LED_PIN, LOW);
// 3. display value on serial monitor (when no object detected)
if (digitalRead(LED_PIN) == LOW)
Serial.println(input);
// 3bis. display "sensor triggered" when value under benchmark and LED on
if (digitalRead(LED_PIN) == HIGH)
Serial.println("sensor triggered");
You will find that your serial output is flooded. You will probably want to add code to limit the output, perhaps only displaying text when the light changes or the sensor output changes.
Just a small nit but you can't easily use if/else with your specification because you specified "< benchmark" and "> benchmark" but not "== benchmark". To write that correctly with if/else you would have to say:
else if (input > BENCHMARK)
If you had said:
if sensor value less than "benchmark" - light the LED otherwise turn the LED off
then the code could be:
