if / else function one time button
Hello.
I have an arduino uno and i want to enable something with the if/else function but i dont want to use a switch.I want to use a button but after the button releases,its function is still enabled.Can anyone help me with that?
You'll need to explain how a plastic shirt button is going to be better than a switch.
I'm going to guess that you have not looked at the state change detection example. You should.
apple32:
Hello.
We’re not mindreaders. Post your code.
You could be more precise! I think you want the "break;" statement to exit a loop or the "return;" statement to exit a function.
you should use something like the Button State Change example shows: http://arduino.cc/en/Tutorial/ButtonStateChange
Like this you can make something like, for example, when you click a button a LED will light (or any other function that you want). The LED will stay on. When you click the button again the LED will turn off. and it will stay off...
