if else if bug?
hi there, it seems the compiler is making something strange with this minimum working example code:
int hundreds;
short pixel;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  hundreds = 0;
  if ((hundreds > 888) && (hundreds <= 0)) {
   pixel = 2;
 }else if ((hundreds > 111) && (hundreds <= 222)) {
   pixel = 3;
 }else if ((hundreds > 222) && (hundreds <= 333)) {
  pixel = 4;
 }else if ((hundreds > 333) && (hundreds <= 444)) {
   pixel = 5;
 }else if ((hundreds > 444) && (hundreds <= 555)) {
   pixel = 6;
 }else if ((hundreds > 555) && (hundreds <= 666)) {
   pixel = 7;
 }else if ((hundreds > 666) && (hundreds <= 777)) {
   pixel = 0;
 }else if ((hundreds > 777) && (hundreds <= 888)) {
   pixel = 1;
   pixel = 8;
 Serial.println(hundreds);
 Serial.println(pixel);
The code never goes into the first if statement and rather goes into the else which is basically wrong due to (hundreds > 888) && (hundreds <= 0) is true . Where is the problem here?
The expression “((hundreds > 888) && (hundreds <= 0))” is never true.
How can it be > 888 and then <= 0 ?
Which Arduino do you have?
renedlog:
While there is no guarantee that the compiler is perfect it is so much more likely that the error is in your code (or mine) that it is a complete waste of time wondering if the compiler is wrong.
...R
If there is a problem, always suspect your code, not the compiler.
