if, else if comparing values
Hi everyone, new here and new to programming as well.
Basically I have a load cell, arduino is reading data, if it's > 1 gram, it sends a message.
Let's say i put 200 grams, it takes the measurement and sends the message. That works fine, but I want it to send a single message if the value is the same across certain time (hence the same weight is still on), but of course if I change the weight to less/more grams send the current weight, again only once.
From my understanding it needs to compare it's self continuously, but only execute one single command.
I used intergers to make the readings more stable, and I don't need the precision of float etc.
Think that's ok?
Maybe I got it all wrong here.
If someone could point me in the right direction it would be great, Thank you!
This is what I have so far:
 int weight;
 int oldweight;
 weight = (scale.get_units(10));    //get the value in grams from the load cell
if (weight > oldweight)
    delay(800);
    SendMessage();
    Serial.println("weight > oldweight");
     else if (weight == oldweight);
       Serial.println("weight == oldweight");
   weight=oldweight;
remove the ; on the end of
it will terminate the if()
The semicolon ends the if statement, so it does nothing.
Thanks guys, but still the same?
Is there any other way I could approach this problem?
  weight=oldweight;Looks the wrong way round to me as oldweight will never change
UKHeliBob:
Came back to say I figured it out, but you've beat me to it.
Yes that is correct just swap oldweight = weight.
Thank you guy's for the help, I would still be struggling if it wasn't for people like you!
3d0:
if the weight is different now to the last time i read it, then
reset the clock
make a note of what the weight is now
make a note of the fact that I have not yet sent a message about this weight
otherwise, if I have already sent a message about this weight
do nothing
otherwise, if the clock has not yet run out
do nothing
otherwise
send out a message about the weight
make a note of the fact that I have sent a message about this weight
