if else if not working
What is wrong with the following code? I have a US sensor attached and read the pulsewidth which I convert to inches (using the given 147 uS/inch conversion). If the sensor detects an object within a range, eg 10-24 inches for test 1, and 24-50 inches for test 2, it prints to monitor and LCD and lights up an LED. All this is still under development so there is still much to do.
However...when it gets to the 3rd condition where inches is between 200 and 350, it does not work. Nothing gets printed. I checked, with a scope the pulsewidth and it is right on when the sensor is in "free space", the max 301 inches or 44 mS pulsewidth. So I know the sensor is picking up the value, but my "if" statement is not making the decision. I've tried moving the "if" around and even put the long range test (the one that doesn't work) up higher...still doesn't work. I've tried Case statements and comparison statements (eg if ((12<= inches) && (inches <=30))) and that works for the first TWO, but not the THIRD. I cannot get this code to respond to a value >200 inches
 pulseW = pulseIn(pwPin, HIGH); //get pulse duration
  int inches = pulseW / scaleFactor;
   if (inRange(inches, 10, 24)) //lab test value
  { digitalWrite (ledCycle, ON); //BLUE
    lcd.setCursor(0, 2);
    lcd.print("NEAR LANE    ");
    digitalWrite (ledCycle, OFF);
    Serial.print ("Near Lane - inches= ");//for testing
    Serial.println (inches);
  else if(inRange(inches, 24, 50)); //lab test value
  { digitalWrite (ledSUV, ON); //GREEN
    lcd.print("FAR LANE     ");
    delay(500);//for test only
    digitalWrite (ledSUV, OFF);
    Serial.print ("Far Lane - inches= ");//for testing
    if(inRange(inches, 200, 350))//max is 301 inches
    { digitalWrite (ledBus, ON); //RED
      lcd.print("NO TRAFFIC     ");
      digitalWrite (ledBus, OFF);
      Serial.print ("No Traffic - reading= ");//for testing
      Serial.println (inches);}
Ups.
#define Ups Oops
I remember back in 1980, working on a PR1ME mainframe :
oops : undo previous command (note: you cannot oops an oops)
I vaguely remember that... I wasn’t a PRIME user, but that rattles a chain in my memory.
I was proudly a DECcie...!
