if else if structure not working - char problem?
I have a nano hooked up to a non-standard membrane keypad from an old video distribution system. Even though it is a 2 x 8 layout, I was able to use the standard 4 x 4 layout, and map all the keys to 0-9 and a-f. That works great.
Now I’m trying to create a structure to let me assign commands to each button press. At first I thought I could use switch case, but I’m not sure that works with the hex characters.
So, I have just tried If and else If to see if I could get it working that way, but I am not having any luck. Here’s my code:
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <Key.h>
#include <Keypad.h>
LiquidCrystal_I2C lcd(0x3f,20,4);
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
{‘4’, ‘3’, ‘2’, ‘1’},
{‘5’, ‘A’, ‘C’, ‘E’},
{‘0’, ‘B’, ‘D’, ‘F’},
{‘9’, ‘8’, ‘7’, ‘6’}
byte rowPins[ROWS] = {11, 10, 9, 8};
byte colPins[COLS] = {7, 6, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
char customKey = customKeypad.getKey();
if (customKey){
String strCustomKey = String(customKey);
Serial.println(customKey);
lcd.clear();
if (strCustomKey = “1”){
lcd.setCursor (0,1);
lcd.print(“You Pressed 1”);
else if (strCustomKey = “2”){
lcd.print(“You Pressed 2”);
else if (customKey = 3){
lcd.print(“You Pressed 3”);
else if (customKey = 4){
lcd.print(“You Pressed 4”);
else if (customKey = 5){
lcd.print(“You Pressed 5”);
else if (customKey = 6){
lcd.print(“You Pressed 6”);
else if (customKey = 7){
lcd.print(“You Pressed 7”);
else if (customKey = 8){
lcd.print(“You Pressed 8”);
else if (customKey = 9){
lcd.print(“You Pressed 9”);
else if (customKey = 0){
lcd.print(“You Pressed 0”);
else if (customKey = “A”){
lcd.print(“You Pressed Clear”);
else if (customKey = “B”){
lcd.print(“You Pressed Enter”);
else if (customKey = “C”){
lcd.print(“You Pressed Source”);
else if (customKey = “D”){
lcd.print(“You Pressed Dest”);
else if (customKey = “E”){
lcd.print(“You Pressed The Up Arrow”);
else if (customKey = “F”){
lcd.print(“You Pressed The Down Arrow”);
customKey = “”;
When I run this, as I press each button, the correct character appears in the serial console - so it is recognizing and displaying the key presses correctly.
But, on the LCD screen, I only get “You Pressed 1”, no matter what button I press.
Why don’t any of the else if statements work?
(p.s. - it didn’t make any difference if I just used “customKey”, or “StrCustomKey”)
else if (customKey = 4){Oops
Every single comparison should be ==
Please remember to use code tags when posting code
Thanks - that was it. Still getting used to C...
And I missed the part in the instructions about the code tags - I know better now.
Thanks!
Why do this when you could test the char returned directly ?
Even when you fix the problem with equals this will not work because you cast the returned char to a String
Yeah, I was just trying the string because it wasn’t working, and I had only changed the first couple for testing. I’ve change them all to the string now, and it works perfectly.
Just for kicks, try not converting to a String and instead test for a char (single character in single quotes) instead
