If ... Else (Need Help!)
Ok, can someone just check my code? (its not perfect) Because the error that states "error: expected '}' before 'else'" keeps appearing! (its on the line indicated by A BUNCH of <<<<<<)
Thanks!
-A
int inches;
int randNumber;
int LM = 10;
int RM = 11;
  for(int i = 175; i < 210; i++)
    analogWrite(RM, i);
    analogWrite(LM, i);
    delay(200);
  if(inches < 7)
    analogWrite(RM,190);
    analogWrite(LM,190);
    Serial.println("stopped");
    randNumber = random(0,1);
    if(randNumber = 0);
      Serial.println("right activate");
      analogWrite(RM, 175);
      analogWrite(RM, 190);
    else      <<<<<<<<<<<<<<<<<<<<<<
      Serial.println("left activate");
      analogWrite(LM, 175);
      analogWrite(LM, 190);
    Serial.println("Going forward");
    long duration, inches;
    pinMode(7, OUTPUT);
    digitalWrite(7, LOW);
    delayMicroseconds(2);
    digitalWrite(7, HIGH);
    delayMicroseconds(5);
    pinMode(7, INPUT);
    duration = pulseIn(7, HIGH);
    inches = microsecondsToInches(duration);
    Serial.println(inches);
    analogWrite(RM,170);
    analogWrite(LM,170);
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
if(randNumber = 0);
:o
if (randNumber == 0)
Remove the semi colon and add another equal sign
