If else syntax questions
Having some trouble with the syntax / format to make an if else work the way I am wanting. It is a portable GPS tracker - where the current behavior in the case of not getting a GPS lock, it uploads 0.000000 for latitude and longitude to a dashboard.
I am trying to get it to only upload battery level when latitude is 0. In the code below, I have the if/else portion in the loop commented out. When I uncomment, it only runs the if portion of commands (and also fails to HTTP post to the dashboard).
Other than this, the tracker does what I need, wakes up from a mercury switch interrupt, connects, obtains GPS (or not), uploads to a dashboard and goes to sleep - would just prefer the resultant dashboard map not include 0 latitude / 0 longitude way points is all.
Thanks for any assistance.
#include "Adafruit_FONA.h"
#include <SoftwareSerial.h>
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/interrupt.h>
#define DEBUG // serial debug prints on-off
#ifdef DEBUG
 #define DEBUG_PRINT(x)       Serial.print(x)
 #define DEBUG_PRINTLN(x)     Serial.println(x)
#else
#endif
#define FONA_PWRKEY 16
#define FONA_TX 14
#define FONA_RX 15
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA_LTE fona = Adafruit_FONA_LTE();
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
char imei[16] = {0};
uint8_t type;
uint16_t battLevel = 0;
float latitude, longitude, speed_kph, heading, altitude;
uint8_t counter = 0;
char URL[100];
char body[100];
char latBuff[12], longBuff[12], locBuff[50], speedBuff[12],
     headBuff[12], altBuff[12], battBuff[12];
  pinMode(2, INPUT_PULLUP);
  #ifdef DEBUG
  #endif
  latBuff[12]=0;
  longBuff[12]=0;
  locBuff[50]=0;
  speedBuff[12]=0;
  headBuff[12]=0;
  altBuff[12]=0;
  battBuff[12]=0;
  DEBUG_PRINTLN(F("*** GPS Tracker ***"));
  pinMode(FONA_PWRKEY, OUTPUT);
  powerOn(true);
  moduleSetup();
  fona.setNetworkSettings(F("hologram"));
  fona.enableGPRS(false);
  counter = 0;
  while (counter < 3 &&!fona.enableGPRS(true)) {
  DEBUG_PRINTLN(F("Failed to turn on LTE, retrying..."));
  counter++;
  delay(2000);
  DEBUG_PRINTLN(F("Turned on LTE!"));
  counter = 0;
  while (counter < 5 &&!netStatus()) {
  DEBUG_PRINTLN(F("Failed to connect to cell network, retrying..."));
  counter++;
  delay(2000);
  DEBUG_PRINTLN(F("Connected to cell network!"));
  battLevel = readVcc();
  counter = 0;
  while (counter < 3 &&!fona.enableGPS(true)) {
  DEBUG_PRINTLN(F("Failed to turn on GPS, retrying..."));
  counter++;
  delay(2000);
  DEBUG_PRINTLN(F("Turned on GPS!"));
  counter = 0;
  while (counter < 20 &&!fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude)) {
  DEBUG_PRINTLN(F("Failed to get GPS location, retrying..."));
  counter++;
  delay(10000);
  DEBUG_PRINTLN(F("GPS Location"));
  DEBUG_PRINTLN(F("---------------------"));
  DEBUG_PRINT(F("Latitude: ")); DEBUG_PRINTLN(latitude);
  DEBUG_PRINT(F("Longitude: ")); DEBUG_PRINTLN(longitude);
  DEBUG_PRINT(F("Speed: ")); DEBUG_PRINTLN(speed_kph);
  DEBUG_PRINT(F("Heading: ")); DEBUG_PRINTLN(heading);
  DEBUG_PRINT(F("Altitude: ")); DEBUG_PRINTLN(altitude);
  dtostrf(latitude, 1, 6, latBuff);
  dtostrf(longitude, 1, 6, longBuff);
  dtostrf(speed_kph, 1, 0, speedBuff);
  dtostrf(heading, 1, 0, headBuff);
  dtostrf(altitude, 1, 1, altBuff);
  dtostrf(battLevel, 1, 0, battBuff);
  sprintf(locBuff, "%s,%s,%s,%s", latBuff, longBuff, altBuff, battBuff);
  //int latcheck;
  //latcheck = atoi(latBuff);
  //DEBUG_PRINT(F("latcheck = ")); DEBUG_PRINT(latcheck);
  //if (latcheck = '0') {
  //counter = 0;
  //const char * token = "hashvalue";
  //sprintf(URL, "http://demo.thingsboard.io/api/v1/%s/telemetry", token);
  //sprintf(body, "{\"batt\":%s}", battBuff);
  //while (counter < 3 && !fona.postData("POST", URL, body)) {
  //DEBUG_PRINTLN(F("Failed to complete HTTP POST..."));
  //counter++;
  //delay(1000); }
  //else {
  counter = 0;
  sprintf(body, "{\"lat\":%s,\"long\":%s,\"alt\":%s,\"batt\":%s}", latBuff, longBuff, altBuff, battBuff);
  counter++;
  delay(1000); }
  moduleOff();
void wakeUpNow() {
  sleep_disable ();
  detachInterrupt(0);
void powerOn(bool onoff) {
  digitalWrite(FONA_PWRKEY, LOW);
  if (onoff) delay(100);
  else delay(1400);
  digitalWrite(FONA_PWRKEY, HIGH);
void moduleSetup() {
  fonaSS.begin(115200);
  DEBUG_PRINTLN(F("Configuring to 9600 baud"));
  delay(5000);
  fonaSS.println("AT+IPR=9600");
  fonaSS.begin(9600);
  if (! fona.begin(fonaSS)) {
  DEBUG_PRINTLN(F("Couldn't find FONA"));
  while (1);
  type = fona.type();
  DEBUG_PRINTLN(F("FONA is OK"));
  DEBUG_PRINT(F("Found "));
  switch (type) {
  case SIM7000A:
  DEBUG_PRINTLN(F("SIM7000A (American)")); break;
  case SIM7000C:
  DEBUG_PRINTLN(F("SIM7000C (Chinese)")); break;
  case SIM7000E:
  DEBUG_PRINTLN(F("SIM7000E (European)")); break;
  case SIM7000G:
  DEBUG_PRINTLN(F("SIM7000G (Global)")); break;
  default:
  DEBUG_PRINTLN(F("???")); break;
  uint8_t imeiLen = fona.getIMEI(imei);
  if (imeiLen > 0) {
  DEBUG_PRINT("Module IMEI: "); DEBUG_PRINTLN(imei);
float readVcc() {
  if (!fona.getBattVoltage(&battLevel)) DEBUG_PRINTLN(F("Failed to read batt"));
  else DEBUG_PRINT(F("battery = ")); DEBUG_PRINT(battLevel); DEBUG_PRINTLN(F(" mV"));
  return battLevel;
bool netStatus() {
  int n = fona.getNetworkStatus();
  DEBUG_PRINT(F("Network status ")); DEBUG_PRINT(n); DEBUG_PRINT(F(": "));
  if (n == 0) DEBUG_PRINTLN(F("Not registered"));
  if (n == 1) DEBUG_PRINTLN(F("Registered (home)"));
  if (n == 2) DEBUG_PRINTLN(F("Not registered (searching)"));
  if (n == 3) DEBUG_PRINTLN(F("Denied"));
  if (n == 4) DEBUG_PRINTLN(F("Unknown"));
  if (n == 5) DEBUG_PRINTLN(F("Registered roaming"));
  if (!(n == 1 || n == 5)) return false;
  else return true;
void moduleOff() {
  DEBUG_PRINTLN(F("Shutting down GPS, GPRS"));
  delay(5);
  fona.enableGPS(false);
  fona.powerDown();
  //powerOn(false);
  MCU_powerDown();
void MCU_powerDown() {
  DEBUG_PRINTLN(F("Shutting down MCU"));
  delay(5);
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  noInterrupts ();
  sleep_enable();
  attachInterrupt(0,wakeUpNow, LOW);
  interrupts ();
  sleep_cpu ();
latcheck is an int, compare it to 0, not '0' (which is the ascii characther code for a zero)
If you are having problems with if, then its worth checking the reference for if;
https://www.arduino.cc/reference/en/language/structure/control-structure/if/
And check that;
if (latcheck = '0')
Is valid.
DrAzzy:
latcheck is an int, compare it to 0, not ‘0’ (which is the ascii characther code for a zero)
Changing to (latcheck = 0), and adding a couple more debug prints on the If an Else:
#ifdef DEBUG
#else
#endif
#define FONA_TX 14
#define FONA_RX 15
uint8_t type;
int latcheck;
char URL[100];
char body[100];
  #ifdef DEBUG
  #endif
  latcheck=0;
  latBuff[12]=0;
  longBuff[12]=0;
  locBuff[50]=0;
  speedBuff[12]=0;
  headBuff[12]=0;
  altBuff[12]=0;
  battBuff[12]=0;
  powerOn(true);
  moduleSetup();
  counter = 0;
  counter++;
  delay(2000);
  counter = 0;
  counter++;
  delay(2000);
  counter = 0;
  counter++;
  delay(2000);
  counter = 0;
  counter++;
  delay(10000);
  if (latcheck = 0) {
  counter = 0;
  DEBUG_PRINTLN(F("If"));
  counter++;
  delay(1000); }
  else {
  counter = 0;
  DEBUG_PRINTLN(F("Else"));
  counter++;
  delay(1000); }
  moduleOff();
void wakeUpNow() {
  sleep_disable ();
  detachInterrupt(0);
  else delay(1400);
  delay(5000);
  fonaSS.begin(9600);
  while (1);
  type = fona.type();
  switch (type) {
  case SIM7000A:
  case SIM7000C:
  case SIM7000E:
  case SIM7000G:
  default:
  if (imeiLen > 0) {
float readVcc() {
  return battLevel;
bool netStatus() {
  else return true;
void moduleOff() {
  delay(5);
  fona.powerDown();
  //powerOn(false);
  MCU_powerDown();
  delay(5);
  noInterrupts ();
  sleep_enable();
  interrupts ();
  sleep_cpu ();
Results in the below debug print:
GPS Location
Latitude: 0.00
Longitude: 0.00
Speed: 0.00
Heading: 0.00
Altitude: 0.00
latcheck = 0Else
---> AT+HTTPTERM
<--- ERROR
---> AT+HTTPINIT
<--- OK
---> AT+HTTPPARA="CID",1
<--- OK
---> AT+HTTPPARA="URL","http://demo.thingsboard.io/api/v1/hashvalue/telemetry"
<--- OK
---> AT+HTTPPARA="CONTENT","application/json"
<--- OK
---> AT+HTTPDATA=54,10000
<--- DOWNLOAD
---> {"lat":0.000000,"long":0.000000,"alt":0.0,"batt":3813}
<--- OK
---> AT+HTTPACTION=1
<--- OK
HTTP status: 200
So it looks like latcheck did equal 0, but it ran the Else anyway?
srnet:
if - Arduino Reference
And check that;
if (latcheck = '0')
Is valid.
Ahh. I see now. Testing.
srnet:
And check that;
if (latcheck = ‘0’)
Is valid.
0100010:
OK - changing to (latcheck == 0) allows it to run the If. Now, just need to figure out why it fails to post.
GPS Location
Latitude: 0.00
Longitude: 0.00
Speed: 0.00
Heading: 0.00
Altitude: 0.00
latcheck = 0If
 ---> AT+HTTPTERM
 <--- ERROR
 ---> AT+HTTPINIT
 <--- OK
 <--- OK
 <--- OK
 <--- OK
 ---> AT+HTTPDATA=13,10000
 <--- DOWNLOAD
 ---> {"batt":3810}
 <--- OK
 <--- OK
HTTP status: 400
Data length: 491
