I have a near complete project that is working fine with If statements. I have five water level indicators spread out on a plastic tank, as the water level lowers, I read the pin and print a line... simple
I'd like to clean it up and learn the Switch case but it confuses me because I have five sensors and five pins. Could someone please give a push in the right direction with a snippet of how to convert the below code to Select Case? I know it has something to do with the way I declare the variable but I'm just not sure.
const int ledpin = 13;
const int water1 = 2;
const int water2 = 3;
const int water3 = 4;
const int water4 = 5;
const int water5 = 6;
// the setup function runs once when you press reset or power the board
Serial.begin (9600);
pinMode(ledpin, OUTPUT);
pinMode (water1, INPUT);
pinMode (water2, INPUT);
pinMode (water3, INPUT);
pinMode (water4, INPUT);
pinMode (water5, INPUT);
// the loop function runs over and over checking water level
if (digitalRead (water1) == HIGH)
digitalWrite(ledpin, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println ("You're full");
else if (digitalRead (water2) == HIGH)
Serial.println ("You're 80%");
else if (digitalRead (water3) == HIGH)
Serial.println ("You're 60%");
else if (digitalRead (water4) == HIGH)
Serial.println ("You're 40");
else if (digitalRead (water5) == HIGH)
Serial.println ("You're 20%");
digitalWrite(ledpin, LOW); // turn the LED off by making the voltage LOW
Serial.println ("You're Empty!");
delay(1500); // wait for a 1/2 second
Is this an assignment? If not, forget about using a switch/case. The switch only works by comparing a single variable to multiple constants. That is not what you have - you're testing the results of a series of individual function calls. The problem doesn't fit the switch/case paradigm.
I'm a somehow advanced programmer but surely not the world best one.
Of course it can be programmed with a switch-case-statement.
But me personal I have no idea how to code it in a way that would reduce the number of lines with code.
a switch-case needs a single variable. This variable must be setup for different values
this would be still an if-statement
or maybe direct portreading and defining a list of values that can be enumerated
or defining an array to go through with a for-loop.
All solutions that are possible but will IMHO reduce readability of the code.
But maybe I'm just not experienced and / or creative enough.
best regards Stefan
New Idea: How about switching to an ultrasonic sensor measuring hight with cm-precision and calculate the volume?
Thank you all for the replies!
This is a personal project to monitor a Methanol tank in my trunk. Not being able to use a Switch Case makes perfect sense now. I stared at examples for an hour and couldn't get my head wrapped around it, now I know why
TheMemberFormerlyKnownAsAWOL:
You could bit-pack the pin readings, and use a simple lookup, no switch/case, no ifs.
Mmmm. Well you get a sparsely populated table that way, since the indices are 0, 1, 0b11, 0b111, 0b1111, and 0b11111. That really suggests switch case handling would be better...
The best solution I can come up with that uses "switch/case" instead of "if/else if/else if/else if" is to convert from inputs to a percentage and then use the switch/case to act on the percentage.
const int WaterPinCount = 5;
const int WaterPins[WaterPinCount] = {2, 3, 4, 5, 6};
const int Percentages[WaterPinCount] = {100, 80, 60, 40, 20};
int OldPercentage = -1; // Invalid value so the first reading will always be 'new'
Serial.begin (115200); // 9600 baud is so 1990's
pinMode(LED_BUILTIN, OUTPUT);
for (int i = 0; i < WaterPinCount; i++)
pinMode(WaterPins[i], INPUT);
int percentage = 0;
if (digitalRead(WaterPins[i]))
percentage = Percentages[i];
// Avoid repeating the same output over and over by only doing
// output when the value changes.
if (percentage != OldPercentage)
OldPercentage = percentage;
switch (percentage)
case 100:
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
case 80:
case 60:
case 40:
case 20:
Serial.print("You're ");
Serial.print(percentage);
Serial.println("%");
case 0:
digitalWrite(LED_BUILTIN, LOW); // turn the LED off
default:
Serial.println("INVALID PERCENTAGE");
