Hi
It does still make that Error
Heres the code
Fading
This example shows how to fade an LED using the analogWrite() function.
The circuit:
- LED attached from digital pin 9 to ground.
Created 1 Nov 2008
By David A. Mellis
Modified 17 June 2009
By Tom Igoe
int ledPin = 9; // LED connected to digital pin 9
int ledPin1 = 10;
int ledPin2 = 11;
long randNumber;
// if analog input pin 0 is unconnected, random analog
// noise will cause the call to randomSeed() to generate
// different seed numbers each time the sketch runs.
// randomSeed() will then shuffle the random function.
randomSeed(analogRead(0));
randNumber = random(3);
Serial.println(randNumber);
delay (50);
if(random = 1); // The Problem Comes Here error: expected unqualified-id before ‘if’
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
delay(30);
else if (random = 2);
analogWrite(ledPin1, fadeValue);
delay(30);
delay(30);
else if (random = 3);
analogWrite(ledPin2, fadeValue);
delay(30);
delay(30);
if (random = 0);
return loop
