I have a piece of code…
for (int i = 0; i < 8; i++) {
temp = (j * 8) + i;
temp3 = ledArray[temp];
if (temp3 >= x ); {
Serial.print(temp3, DEC);
Serial.println(x, DEC);
ledOut |= bit(i);
} //end if
} //next i
I had all the functions of temp3 = blabla embedded in the if statement, and took them out just to make sure.
Now…the way it works is I’m breaking an array of 24 into chunks of 8 for evaluation then shifting out to a shift register.
It used to work with just one shift register, but as soon as I made the array bigger it no longer works:
Serial Display:
01
01
01
01
01
01
01
01
After i, before shiftout
255
Zero is not greater than or equal to one, so it should not fire the if, but it does…8 times in a row. No matter what data gets passed to this statement it doesnt seem to work.
255 is the decimal format of the bitwise setting of all 8 bits in the byte ledArray.
**back story, the whole point of this is I’m doing 3 bit (8 step) pwm control of an array of leds through shift registers by shifting at maximum speed. I’m THIS close to giving up on the pwm concept - once the array gets as big as I hope (hundreds of leds) pwm will be unfeasable - but at this small prototyping stage I have some cool animations for an 8 led system…blargh.
Thanks in advance! Please tell me I’m missing something stupid.
