if function is not working
hey guys for one of my project i use rc522 i can read the data from card but when i try to use if function for controlling the data it fails
#include <SPI.h>
#include <MFRC522.h>
int val[3];
int as1;
int as2;
int as3;
int as4;
String uid;
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance.
byte cardPresent;
  Serial.begin(9600); // Initialize serial communications with the PC
  SPI.begin();      // Init SPI bus
  mfrc522.PCD_Init(); // Init MFRC522 card
// Serial.println("Ready!");
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
  return;
//Serial.print("Card UID:");
        for (byte i = 0; i < mfrc522.uid.size; i++) {
                val[i] = (mfrc522.uid.uidByte[i]);
        String as1 = String(val[0]);
        String as2 = String(val[1]);
        String as3 = String(val[2]);
        String as4 = String(val[3]);
        uid = as1 + as2 + as3 + as4;
        Serial.println(uid);
        if (String(uid) = "18204122133"){
          Serial.println("Acces");
        delay(50);
in this code if the card data is 18204122133 it has to say acces and it does but when i make it read another card it still says acces what can i do please help thanks
Or
if (String(uid) == "18204122133")
The second option worked thanks but why what is the diffrence
= is assign.
== is comparison.
https://www.arduino.cc/en/Reference/Assignment
The second (a comparison) makes sense, but the first (an assignment) doesn't.
Thanks guys
A little bit more to what others have said "=" is an assignment operator AND it is always TRUE (the always true part often confuses people)
gpsmikey:
It does not always return true. It returns the value of the right side of the expression. If that happens to be zero, it will return false.
Oooops - correct. My bad!
aarg:
