if (750 < value < 900)
digitalWrite(6, HIGH);
delay(5);
digitalWrite(6, LOW);
i want to work this code when i push the button
if ((buttonState == HIGH) && (750 < value < 900))
delay(5);
but it dosn't work how can i solve this
at excel i do like this =IF(B3=1;A32,05;IF(B3=2;A3 1,3;"")) is this work same as arduino
thank you
if ((buttonstate == HIGH) && ((750 < value) && (value < 900)))
DrAzzy
August 26, 2016, 6:59pm
3
Almost.
This is wrong though:
(750 < value < 900)
that will test if 750 is less than value - if it is, the (750 < value) will be 1 else 0. And either way, 0 or 1 are both lower than 900, so that will always return true.
You may have to deal with debouncing the switch (there's lots of material on this around the web), depending on your use case.
thank you for your help
it worked !
this my final codes
int sensorPini = A0;
int olculenIsikDegeri = 0;
int butonPini = 4;
int butonDurumu = 0;
pinMode(4, INPUT);
//Serial.begin(9600);
pinMode(13, OUTPUT);
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
butonDurumu = digitalRead(butonPini);
olculenIsikDegeri = analogRead(sensorPini);
if (butonDurumu == LOW)
digitalWrite(3, HIGH);
digitalWrite(13, HIGH);
digitalWrite(5, HIGH);
digitalWrite(3, LOW);
digitalWrite(13, LOW);
digitalWrite(5, LOW);
if ((butonDurumu == HIGH) && ((355 < olculenIsikDegeri) && (olculenIsikDegeri < 500)))
delay(1);
if ((butonDurumu == HIGH) && ((210 < olculenIsikDegeri) && (olculenIsikDegeri < 355)))
delay(1);
if ((butonDurumu == HIGH) && ((110 < olculenIsikDegeri) && (olculenIsikDegeri < 210)))
delay(1);
//if (butonDurumu == HIGH)
//Serial.println(olculenIsikDegeri);
