This is my final code
everything works perfectly except the auto mode
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1,MOTOR12_1KHZ);
AF_DCMotor motor2(3, MOTOR12_1KHZ);
Servo myservo;
String readString;
int LDR = 0; //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDRValue = 0; //that’s a variable to store LDR values
int light_sensitivity = 500;//This is the approx value of light surrounding your LDR
int distance = 100;
int speedSet=0;
boolean goesForward=false;
Serial.begin(9600); //start the serial monitor with 9600 buad
pinMode(13, OUTPUT); //we mostly use 13 because there is already a built in yellow LED in arduino which shows output when 13 pin is enabled
myservo.attach(9);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
LDRValue = analogRead(LDR); //reads the ldr’s value through LDR
delay(50); //This is the speed by which LDR sends value to arduino
if (LDRValue < light_sensitivity)
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
while (Serial.available()) {
delay(3);
char c = Serial.read();
readString += c;
//////////////////////Problem area////////////////////////
if (readString == "auto mode")
int distanceR = 0;
int distanceL = 0;
delay(40);
if (distance<=15){
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL){
turnRight();
moveStop();
turnLeft();
moveStop();
moveForward();
////////////////////////////end of problem area/////////////////////////////////////////////////////////
else if (readString == "go")
moveForward();
if (readString == "left")
turnLeft();
else if (readString == "right")
turnRight();
else if (readString == "stop")
moveStop();
else if (readString == "reverse")
moveBackward();
readString="";
///////////////////////////group declarations///////////////////////////////////////////
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
delay(5);
void turnRight() {
delay(300);
void turnLeft() {
delay(300);
rpt007
January 6, 2017, 12:48pm
2
What does the problem zone do or not do and what is your expectation what it should do?
You haven' learned from your other thread; "not working" does not mean anything. What do you expect it to do and what is it doing.
other thread
I guess you want to auto mode to keep running, but it probably runs only once, and then you have to type automode again right?
If that is the case try this.
boolean automode = false;
if (readString == "auto mode") {
automode = true;
else {
automode = false;
if (automode) {
.... // put here the part that you want to run
int distanceR = 0;
int distanceL = 0;
delay(40);
if (distance<=15){
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
delay(200);
delay(200);
turnRight();
moveStop();
turnLeft();
moveStop();
moveForward();
Let me know if it worked.
rpt007:
I expect to be an object avoiding robot but it doesn't do anything
Jashman:
akatchi:
automode = true;
else {
automode = false;
if (automode) {
int distanceR = 0;
int distanceL = 0;
delay(40);
if (distance<=15){
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
delay(200);
delay(200);
turnRight();
moveStop();
turnLeft();
moveStop();
moveForward();
It didn't work
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
Servo myservo;
String readString;
int distance = 100;
int speedSet=0;
myservo.attach(9);
myservo.write(115);
delay(2000);
delay(100);
delay(100);
delay(100);
delay(100);
delay(3);
readString += c;
//////////////////////Main area////////////////////////
automode = true;
moveForward();
turnLeft();
turnRight();
moveStop();
moveBackward();
else {
automode = false;
if (automode) {
int distanceR = 0;
int distanceL = 0;
delay(40);
if (distance<=15){
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
delay(200);
delay(200);
turnRight();
moveStop();
turnLeft();
moveStop();
moveForward();
readString="";
int lookRight()
myservo.write(50);
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
if(cm==0)
cm = 250;
return cm;
void moveStop() {
if(!goesForward)
goesForward=true;
delay(5);
goesForward=false;
delay(5);
void turnRight() {
delay(300);
void turnLeft() {
delay(300);
system
January 6, 2017, 1:35pm
7
Jashman:
It didn't work
Clearly the message isn't getting through to you.
Thread locked.
Imagine walking into a garage and saying "My car doesn't work. It's a white car. Please fix it."
How do you think that would be greeted by the staff?
