IDE 2.2.1
bool debug = 0;
void setup() { //setup()
} //setup()
void loop() { //loop()
if (debug = 1) { //debug
Serial.println("EthernetUDP_test1.ino");
} //debug
} //loop()
"if" is not capitalized in the reference library, so I tried it that way. The file as shown compiles and downloads to my Uno. The results are;
EthernetUDP_test1.ino......
"debug" shows false, yet the script runs as if "debug" was true.
I'm obviously doing something wrong. What is it?
v205
October 10, 2023, 8:00pm
3
mancera1979:
try
if(debug==1)
Exactly,
The reason for that is if you use
if(debug=1)
You are setting debug to 1
If you use:
if(debug==1)
You are checking if it equals one or not
awneil
October 10, 2023, 8:03pm
4
Exactly.
and the value of the expression within the if()
is also 1 - so the if()
will always see that as true
Good development tools will warn you about mistakes like this. Before such tools were commonly available it was good practice to write the if statement like
if (1 == debug)
That way if you mistakenly typed "=" instead of "==" it would fail to compile and be an obvious error.
Do you have any suggestions for better development tools?
v205
October 11, 2023, 5:48pm
8
Better dev tools?
Like IDEs?
For a beginner you could try and use the autocomplete in Arduino IDE 2.x.x
Eclipse IDE?
fester225:
One thing you must do is to go to the preferences pane in the IDE and crank up all compiler messages and verbosity.
Then you will get warnings about some things like this one that hung you up for a bit.
Heed the red ink, and if it is talking about your code, fix your code until there are no warnings.
HTH
a7
system
Closed
April 8, 2024, 6:53pm
10
