I need an if() statement to run continuously, without stopping the rest of the loop. How can I do this?
There can be no brakes... I have a bunch of delays in the rest of the program, but I need to keep both of these individual program parts running at the same time.
if(x is true)
set a flag;
if (flag)
do one part
Reset the flag when complete.
DON'T use delays if you need something time critical!!!!!!!!!!!!!!!!!
Well it's obvious that I don't use delays with time-critical information, but the delays are only for sending info to the groundstation. I can't do that every ms hahaha I do that every 2 sec
For the resto of your response, you say that I flag something, but imagine: the flag is false, so it's working on that part of the program. Halfway this process my flag turns false, does it then stop what it's doing? Cause I assume it goes on finishing that loop (Which includes delays)
How about posting your sketch so that we can see what you are doing ?
Get rid of the delays and use a millis() based approach instead.
#include <Servo.h>
#include <Adafruit_GPS.h>
#include <Wire.h>
#include <SPI.h>
#include <SoftwareSerial.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
bool maxheight = false;
bool deploy = false;
float servoAltitude = 0;
Servo servo;
#define BME_SCK 15
#define BME_MISO 14
#define BME_MOSI 16
#define BME_CS 3
#define SEALEVELPRESSURE_HPA (1024.67) // Meet de druk op de grond!
Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
mySerial.begin(9600);
// BME680
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150);
delay(5000);
// GPS
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
GPS.sendCommand(PGCMD_ANTENNA);
mySerial.println(PMTK_Q_RELEASE);
// Servo Motor
delay(200);
servo.attach(6);
delay(200);
servo.write(180);
delay(200);
servo.detach();
delay(200);
uint32_t timer = millis();
// Parsing
char c = GPS.read();
if ((c))
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA()))
return;
if (millis() - timer > 2000) {
timer = millis();
// GPS
if (GPS.fix) {
Serial.print("\n");
Serial.print("Location:");
Serial.print(GPS.latitudeDegrees, 4);
Serial.print(", ");
Serial.println(GPS.longitudeDegrees, 4);
mySerial.print("\n");
mySerial.print("Location:");
mySerial.print(GPS.latitudeDegrees, 4);
mySerial.print(", ");
mySerial.println(GPS.longitudeDegrees, 4);
// BME680
Serial.print("\n");
Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
mySerial.print("Temperature = ");
mySerial.print(bme.temperature);
mySerial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
mySerial.print("Pressure = ");
mySerial.print(bme.pressure / 100.0);
mySerial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
mySerial.print("Humidity = ");
mySerial.print(bme.humidity);
mySerial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
mySerial.print("Gas = ");
mySerial.print(bme.gas_resistance / 1000.0);
mySerial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
mySerial.print("Approx. Altitude = ");
mySerial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
mySerial.println(" m");
// Servo Motor
servoAltitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
// Servo Motor: Max Height Initialization
if (servoAltitude >= 1) { mySerial.println("Above 1 m"); maxheight = true; }
// Servo Motor: Deployment
if (maxheight == true and servoAltitude <= 0.5)
mySerial.println("Deploying at height: "); mySerial.print(servoAltitude);
delay(100);
servo.attach(6);
delay(100);
servo.write(90);
delay(700);
servo.detach();
delay(100);
maxheight = !maxheight;
I need the servo to rotate "EXACTLY" when the altitude drops below 0.5. what it does now, is finishing the first part of the loop, before checking to see if the altitude has drops. This leads to a maximum of 2 second delay. This would mean the parachute would deploy 36 meters too low
I see no need for a delay to do that!
* Do stuff every 2 seconds
unsigned long lastTimeRun = 0;
const long interval = 2000;
// do setup stuff here
unsigned long MillisNow = millis();
if (MillisNow - lastTimeRun >= interval)
//Do stuff here
lastTimeRun = MillisNow;
Oh, i'm stupid. I had one unnesessary delay. let me try something...
timer += 2000;
Unless you think all that code take close-to zero time.
#include <Servo.h>
#include <Wire.h>
#include <SPI.h>
int mhact = 1;
Servo servo;
#define BME_SCK 15
#define BME_MISO 14
#define BME_MOSI 16
#define BME_CS 3
#define SEALEVELPRESSURE_HPA (1025.06) // Meet de druk op de grond!
// BME680
if (!bme.begin()) {
while (1);
delay(5000);
// GPS
GPS.begin(9600);
// Servo Motor
delay(200);
servo.attach(6);
delay(200);
servo.write(180);
delay(200);
servo.detach();
delay(200);
// Parsing
if ((c))
return;
timer = millis();
// GPS
if (GPS.fix) {
Serial.print("\n");
Serial.print(", ");
// BME680
Serial.print("\n");
// Servo Motor
if (servoAltitude >= 1 and mhact == 1)
{ mySerial.println("Above 1 m"); Serial.println("Above 1 m");
maxheight = true; mhact = mhact-1; }
{ mySerial.print("Deploying at height: "); mySerial.println(servoAltitude);
Serial.print("Deploying at height: "); Serial.println(servoAltitude);
delay(100);
servo.attach(6);
delay(100);
servo.write(90);
delay(700);
servo.detach();
delay(100);
This is my code now, however it's still not rotating at the moment I want it to. It rotates when the last packet has been sent. Can someone show me what to change?
If you factored your code into functions, or used the auto format tool, (or both) you would see instantly where your problem is.
Uhhhm how does that work?
It cuts out all the visual noise, and allows you to concentrate on structure.
#include <Servo.h>
#include <Wire.h>
#include <SPI.h>
int mhact = 1;
Servo servo;
#define BME_SCK 15
#define BME_MISO 14
#define BME_MOSI 16
#define BME_CS 3
// BME680
if (!bme.begin()) {
while (1);
delay(5000);
// GPS
GPS.begin(9600);
// Servo Motor
delay(200);
servo.attach(6);
delay(200);
servo.write(180);
delay(200);
servo.detach();
delay(200);
// Parsing
if ((c))
return;
timer = millis();
// GPS
if (GPS.fix) {
Serial.print("\n");
Serial.print(", ");
// BME680
Serial.print("\n");
// Servo Motor
maxheight = true; mhact = mhact - 1;
delay(100);
servo.attach(6);
delay(100);
servo.write(90);
delay(700);
servo.detach();
delay(100);
This is what it looks like formatted. Can you help me figure out how to get the servo to turn when it gets below 0.5 m? It now only turns after having finished sending the last packet. I don't want it to send that packet though, I want it to go straight to where it rotates.
When I said factoring reduces the visual noise (in this, and your previous thread) I really meant it.
Can you see that this
looks an awful lot like this
Noise. Distracting.
Yeah but I can't just leave that out, I need to show it on my Serial Monitor when I'm not sending the info and I need to show it on the serial monitor I am sending to
#include <Servo.h>
#include <Wire.h>
#include <SPI.h>
int mhact = 1;
Servo servo;
#define BME_SCK 15
#define BME_MISO 14
#define BME_MOSI 16
#define BME_CS 3
// BME680
if (!bme.begin()) {
while (1);
delay(5000);
// GPS
GPS.begin(9600);
// Servo Motor
delay(200);
servo.attach(6);
delay(200);
servo.write(180);
delay(200);
servo.detach();
delay(200);
// Parsing
if ((c))
return;
timer = millis();
// GPS
if (GPS.fix) {
// BME680
// Servo Motor
delay(100);
servo.attach(6);
delay(100);
servo.write(90);
delay(700);
servo.detach();
delay(100);
Okay, here it is without the "noise" you were talking about, is this what you mean?
I never said anything about "leaving it out".
It's the same information (or, as I've said before, it should be the same information), going to different destinations, that's all.
Okay, thank you! How can I make it smaller? Is there a command to make the information go to 2 destinations at once?
Yes.
It's called a function.
