If oled connected-> initialise
Hello,
Hi have a project wich works perfectly fine, we need to initiate the oled within the setup part of the code.
But i want the oled display more as optional feature, is there a way to detect if there is an oled on the i2c bus?
Maybe the if statement/if case could be applied someone with some tips hints or perhaps an example?
Yes, you just ask whether the specific slave device is on the bus. e.g.
    Wire.beginTransmission(0x3C);
    byte result = Wire.endTransmission(1);
Read the Wire documentation for the result values Arduino - WireEndTransmission
99.9% of current SSD1306 / SH1106 style OLEDs will ACK correctly.
The first OLEDs to appear on the Ebay market did not ACK correctly. Unless your OLED is 5 years old you should have a good one.
David.
Thanks David, that little hint did it!
This topic was automatically closed after 66 days. New replies are no longer allowed.
