IF OUTPUT IS HIGH DO CODE
What I’m trying to do is if ouput in high then do code which is turn on led2 when 1st led is on
#include <wprogram.h>
#include <wiring_private.h>
#include <pins_arduino.h>
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led1, INPUT);
  if (led1 == HIGH) {
    delay(250);
    digitalWrite(led2, HIGH);
    delay(300);
    digitalWrite(led2, LOW);
  delay(250);
  digitalWrite(led1, HIGH);
  digitalWrite(led3, HIGH);
  delay(300);
  digitalWrite(led1, LOW);
  digitalWrite(led3, LOW);
I, Septillion, hereby grant you to do so!
But really, what is the problem? Does not work isn't an answer :wink:
AND WHY DO YOU SCREAMMMMMMMMMMMMMMMMMMMM?!
(deleted)
Where does led1 ever get set HIGH ?
Is led1 an INPUT or an OUTPUT ?
Note that you can digitalRead() the state of a pin set to be an OUTPUT but not the other way round
spycatcher2k:
if (led1 == HIGH)
Perhaps
if (digitalRead(led1) == HIGH)
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
if (led1 == HIGH)
    delay(250);
    delay(300);
  delay(250);
  delay(300);
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
    delay(250);
    delay(300);
  delay(250);
  delay(300);
i
both of these code dont work as I tried them already
hipradeep@hotmail.co.uk:
dont work
What did I tell you :wink:
septillion:
Tell us what does happen!
Can you please answer the questions in reply #3 ?
septillion:
Error compiling for board Arduino Uno
Is the error a secret?
    delay(250);
    delay(300);
There’s your loop().
Anything after that is Not in loop() and is Not in a function.
You need to fix your pairings of { and } so that all code is within a pair of them, and also within the final } that ends loop().
CTRL-T should help you spot the pairing errors.
UKHeliBob:
I want led 1 to output HIGH but if it is HIGH then it will turn on led2
CrossRoads:
    delay(250);
    delay(300);
There's your loop().
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
    delay(250);
  delay(300);
  delay(250);
  delay(300);
I did auto format but still get an error when uploading
still get an error
you can share it - we’re friends.
I haven’t seen that one for a long time. Which version of the IDE did you resurrect?
Then why on earth do you make it an input then?
And that error is still top secret, isn't it?
PS One thing what's not top secret is your e-mail address by the way. Not very smart to use that as a public username :wink:
AWOL:
you can share it - we're friends.
that error is gone now but it doesnt do what i want it to.
i want the if statement to check if led1 is on and when its on led2 turns on!!!
but led2 is blinking regardless of led1 on or off.
    delay(250);
The only thing that's in the if is the delay() :wink:
septillion:
delay(250);
The only thing that's in the if is the delay() ;)
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
  delay(250);
  delay(300);
    delay(250);
    delay(300);
Still blinking regardless of what led1 is doing.
That's the same code with different indentation, isn't it?
Still, the only thing in the if() is the delay() :wink: Arduino is C/C++, not Python. The indentation is an aid for you but the compiler doesn't give a f* :wink:
int led1 = 11;
int led2 = 8;
int led3 = 3;
int contact0 = 0;
  delay(250);
  delay(300);
  if (digitalRead(led1) == HIGH){
    delay(300);
Here is the right answer.
THANK YOU
