if problem
#include <LiquidCrystal.h>
LiquidCrystal lcd(2,3,4,5,6,7);
int timer = 0;
int ledtimer = 0;
int red = 0;
lcd.begin(16,2);
timer = +
ledtimer = +
if (timer == 1000){
lcd.write(“Merry Christmas!”);
else if(timer == 2000){
lcd.clear();
lcd.write(“Happy holidays!”);
else if(timer == 3000){
lcd.clear();
lcd.write(":)");
else if(timer > 3000){
timer = 0
if (ledtimer==1000){
digitalWrite(red) = HIGH;
else if (ledtimer==1500){
digitalWrite(green) = HIGH;
else if (ledtimer==2000){
digitalWrite(red) = LOW;
else if (ledtimer==3000){
digitalWrite(blue) = HIGH;
else if (ledtimer==3400){
digitalWrite(green) = LOW;
else if (ledtimer==5000){
else if (ledtimer < 5000){
ledtimer = 0
the error message is
C:\Users\Admin\Documents\Arduino\sketch_dec23a\sketch_dec23a.ino: In function ‘void loop()’:
sketch_dec23a:17:3: error: expected primary-expression before ‘if’
if (timer == 1000){
sketch_dec23a:20:3: error: ‘else’ without a previous ‘if’
sketch_dec23a:30:3: error: expected ‘;’ before ‘}’ token
sketch_dec23a:32:21: error: too few arguments to function ‘void digitalWrite(uint8_t, uint8_t)’
In file included from sketch\sketch_dec23a.ino.cpp:1:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:134:6: note: declared here
void digitalWrite(uint8_t, uint8_t);
sketch_dec23a:35:18: error: ‘green’ was not declared in this scope
sketch_dec23a:38:21: error: too few arguments to function ‘void digitalWrite(uint8_t, uint8_t)’
sketch_dec23a:41:18: error: ‘blue’ was not declared in this scope
sketch_dec23a:44:18: error: ‘green’ was not declared in this scope
sketch_dec23a:47:21: error: too few arguments to function ‘void digitalWrite(uint8_t, uint8_t)’
sketch_dec23a:51:3: error: expected ‘;’ before ‘}’ token
exit status 1
you missed a ';'
timer = +
  ledtimer = +
here
    timer = 0
and here
anyway you likely meant :
timer ++;
  ledtimer ++;
the correct syntax for digitalWrite() would be,
 digitalWrite(red,HIGH);
also you did declare red (int red=0;) but not green and blue.
This:
 timer = +
  ledtimer = +
each statement need to end with semicolon and specifically this does not look like finished. Should be += 1; or what?
BTW: Do not use quote button for the code but code tags.
