I am doing a command and that can be sent through the serial monitor
the problem is that when I want to detect it through an if nothing happens and the loop starts again
Serial.println("Introduce el comando");
while(Serial.available()==0){}
String i = Serial.readString();
i = "Hola";
if(i == "Hola"){
Serial.println("Como estas");
digitalWrite(13, LOW);
If line endings in the serial monitor is not set to No Line Ending a line feed and/or carriage return are sent with whatever is entered. "Hola\r\n" is not equal to "Hola". Set line endings to "No Line Ending" and try your code after commenting out the
while (Serial.available() == 0) {}
//i = "Hola";
if (i == "Hola")
trim() removes leading and trailing whitspace
spaces, tabs, newlines, carrageReturns, vertical tab and form feed.
so if your readString() reads in a newline or NL&CR, trim() will remove it before you try
i == "Hola"
If you are reading in text check out my Arduino Software Solutions which has number of sample sketches for reading from Serial with their pros and cons.
Also if you are using Strings check out my tutorial on Taming Arduino Strings
