I'm making a device that senses temperature below a certain level and then turns a red LED if the temperature is below that level. There is a screenshot of my virtual model on TinkerCad in this post.
If I want to I want to turn on the LED IF the temperature sensor senses temperature below the level. How do I write this in the code? Sorry if this is a simple question , I am new to electronics.
What type of temperature sensor do you have? It will probably need a resistor, and maybe also an opamp.It must be connected to an analog input pin (A0 .. A5).
The led must have a series resistor, with a value of 470 .. 1000 ohm, and be connected between a GPIO pin (2 .. 12) and GND.
The code is simple:
if (temp < 18)
  digitalWrite(ledPin, HIGH);
  digitalWrite(ledPin, LOW);
But I think you should first experiment with some of the example sketches in the IDE, to get some understanding of the programming code for an Arduino.
Erik_Baas:
You will not be able to finish this project if you don't know how to program an Arduino. We can help you if there is a problem, but you must do (most of) it yourself.
