if statement confusing data ( or me ) SOLVED
I am sending some data to a logger, ( all sent as bytes ) , and have just got a testing code at the receive end, with the results monitored with Terminal on the PC.
If I just send all the data and time/date with the code below it logs fine :-
void checkprinter () {  //check and see if a data packet has come in.
  if(ET.receiveData()){
    int(PIN ) = mydata.PIN ;    //  PIN 33 for Radiant
    if(PIN == 33 ){
      Serial.print (" PIN OK = "  );
      Serial.println (PIN );
      int( qgps) = mydata.qgps;
      if ( qgps == 0 ){
        searching = 1;
        queuetype = 1;
      if ( qgps == 1 ){
        searching = 0;
        queuetype = 0;
      if ( qgps == 2 ){
        searching = 1;
        queuetype = 1;
      if ( qgps == 3 ){
        searching = 0;
        queuetype = 0;
      int (number) = mydata.number;
      // if (searching == 0 ) { // only update realtime clock if gps locked
      int( clockyear) =  mydata.clockyear ;
      clockyear = clockyear + 2000 ;
      int( clockmonth ) = mydata.clockmonth;
      int ( clockday) = mydata.clockday;
      int ( clockhours) = mydata.clockhours;
      int ( clockmins) = mydata.clockmins;
      // } //  end of if seraching - 0
      Serial.print (" qgps = "  )      ;
      Serial.println (qgps);
      Serial.print (" number = "  )    ;
      Serial.println (number);
      Serial.print (" searching = "  ) ;
      Serial.println (searching);
      Serial.print (" queuetype = "  ) ;
      Serial.println (queuetype);
      Serial.print (" clockmins = "  ) ;
      Serial.println (clockmins);
      Serial.print (" clockhours = "  );
      Serial.println (clockhours);
      Serial.print (" clockday = "  )  ;
      Serial.println (clockday);
      Serial.print (" clockmonth = "  );
      Serial.println (clockmonth);
      Serial.print (" clockyear = "  ) ;
      Serial.println (clockyear);
    }  //  end of if pin =33
  } //  end of if any rx
  //you should make this delay shorter then your transmit delay or else messages could be lost
  delay(250);
The result is PIN OK = 33
qgps = 3
number = 2
searching = 0
queuetype = 0
clockmins = 35
clockhours = 8
clockday = 15
clockmonth = 4
clockyear = 2013
If I include the if statement that I commented out , as I only want to update the loggers clock if the GPS time coming in as right ie the remote GPS is locked, I lose the time and get as below
    if(PIN == 33 ){
      if ( qgps == 0 ){
        searching = 1;
        queuetype = 1;
      if ( qgps == 1 ){
        searching = 0;
        queuetype = 0;
      if ( qgps == 2 ){
        searching = 1;
        queuetype = 1;
      if ( qgps == 3 ){
        searching = 0;
        queuetype = 0;
  delay(250);
I get the times as below
PIN OK = 33
qgps = 3
number = 2
searching = 0
queuetype = 0
clockmins = <0>
clockhours = <0>
clockday = <0>
clockmonth = <0>
clockyear = <0>
the declared variables are
 #include <EasyTransfer.h>
  //create object
  EasyTransfer ET;
  int ledPin = 10;
  int searching;
  int queuetype;
   byte number;
  byte clockyear;
   byte clockmonth;
   byte clockday;
  byte clockhours;
  byte clockmins;
   byte qgps;
  struct RECEIVE_DATA_STRUCTURE{
    //put your variable definitions here for the data you want to receive
    //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
    // int blinks;
    // int pause;
     byte PIN;  // PIN 33 for Radiant
   //  byte searching;  //  gps locked = 1
     byte number; // broken down for old system and eeprom?
  //   byte numremainder;
     byte clockyear;
     byte clockmonth;
     byte clockday;
     byte clockhours;
     byte clockmins;
     byte qgps;   // 0 for no lock normal ,1 for lock normal , 2 for no lock express, 3 for lock express
 //  byte clocksecs;
  //give a name to the group of data
  RECEIVE_DATA_STRUCTURE mydata;
  void setup(){
    Serial.println("setup");
    //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
    ET.begin(details(mydata), &Serial);
    pinMode(ledPin, OUTPUT);
    checkprinter ();
So it would seem that searching is never == 0, thus the mydata calls are never made.
Yet qgps == 3 every pass, which your serial.print's confirm. Very odd.
Logic question for you - what is different between qgps states 0,2 and 1,3? Both set the flags the same.
What is this? The left side is casting PIN to an int. Why?
Same here. The usage of the int() macro is wrong.
Thanks guys, I got myself mixed up there.
How many other Great Grandfathers get confused with this sometimes ? :slight_smile:
I didn't realise that you could have "byte number" in the EasyTranfer and also declare " int byte ".
As soon as I did that I could dump all the confusing bits and now have as below and it works.
I had to trim the tx data down as the fifo in the rf modules was breaking the message into 2, which confused the ET so I made everyting bytes, and combined the gps searching with the queue type in one byte - qgps. It all goes through fine now in one burst.
( I don't have time to find the wireless specs again to change the message length )
I reverted to my orig code for reading the qgps
   if(PIN == 33 ){ Serial.print (" PIN OK = "  ); Serial.println (PIN );
   if ( qgps == 0 || 2 ){   searching = 0 ;   }  else {   searching = 1;  }
 if ( qgps == 1 || 3 ){  queuetype = 0 ; } else {  queuetype = 1;  }
       clockyear = mydata.clockyear + 2000 ;
       clockmonth  = mydata.clockmonth;
       clockday = mydata.clockday;
       clockhours = mydata.clockhours;
       clockmins = mydata.clockmins;
        Serial.print (" qgps = "  )      ;  Serial.println (qgps);
        Serial.print (" number = "  )    ;  Serial.println (number);
        Serial.print (" searching = "  ) ;  Serial.println (searching);
        Serial.print (" queuetype = "  ) ;  Serial.println (queuetype);
        Serial.print (" clockmins = "  ) ;  Serial.println (clockmins);
        Serial.print (" clockhours = "  );  Serial.println (clockhours);
        Serial.print (" clockday = "  )  ;  Serial.println (clockday);
        Serial.print (" clockmonth = "  );  Serial.println (clockmonth);
        Serial.print (" clockyear = "  ) ;  Serial.println (clockyear);
      delay(250);
