Hello dear friends,
i am new on arduino research and i have problem in the code.
when i buy fingerpriint sensor i have two sketches there is :
- Enroll = This code for save our finger to database
#include <Dyrobot_Fingerprint.h>
#if ARDUINO >= 100
#include <NewSoftSerial.h>
#else
#include <SoftwareSerial.h>
#endif
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Dyrobot_Fingerprint finger = Dyrobot_Fingerprint(&mySerial);
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
void loop() // run over and over again
Serial.println("Type in the ID # you want to save this finger as...");
uint8_t id = 0;
while (true) {
while (! Serial.available());
char c = Serial.read();
if (! isdigit(c)) break;
id *= 10;
id += c - '0';
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
- Fingerprint = this code for check our fingerprint
#if ARDUINO >= 100
#else
#endif
int getFingerprintIDez();
#if ARDUINO >= 100
#else
#endif
while (1);
Serial.println("Waiting for valid finger...");
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
Serial.println("No finger detected");
return p;
return p;
return p;
default:
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
Serial.println("Found a print match!");
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
but now how to make it become one sketch, so in the serial monitor i can choice to enroll or checkfingerprint.
are possible using if statement? thanks dear
