If statement help in code
Hello!
Im making an arduino project that requires it to turn a LED on when the HC-SR04 detects a object within 20cm.
I know how to use the if statement, but when tried being used in the project, the led doesnt work. ( i’ve tested the conections on the arduino, they are fine and also the led, it works). May someone please help me here with the code, because i dotn know what to put in when i say
if ({dont know what to put} < 15)
digitalWrite(ledPin, HIGH)
digitalWrite(ledPin, LOW)
thanks very much
Code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, A0, A1, A2, A3, A4, A5);
#define trigPin 12
#define echoPin 13
  lcd.begin(16,2);
  lcd.clear();
  ** LCD code ***
  delay(5000);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
int Dist(){
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  return distance;
  lcd.setCursor(0,1);
  lcd.print("Eco-Can Project");
  lcd.setCursor(0,0);
  lcd.print("Distance: ");
  lcd.setCursor(10,0);
  lcd.print(Dist());
  lcd.print("cm  ");
  delay(100);
thanks for helping
  • clock
clockpie_5436:
Hello!
thanks very much
Code:
#define trigPin 12
#define echoPin 13
  lcd.begin(16,2);
  lcd.clear();
  ** LCD code ***
delay(5000);
int Dist(){
  return distance;
lcd.setCursor(0,1);
  lcd.print(“Eco-Can Project”);
  lcd.setCursor(0,0);
  lcd.print(Dist());
  lcd.print("cm  ");
delay(100);
thanks for helping
- clock
Use your serial monitor to display the values you receive from the sensor. Look at example programs and set your serial monitor to 9600 baud. Then Serial.write a value or Serial.println a value.
Paul
