If statement ignored after changed value .
Hi guys , I successfully can changed data now using GSM module and EEPROM . but after i changed it the “IF Condition” ignored the whole state. This is the scenario , if I text GSM module "STI(password)SET, then the next text is the new password “JJJ” . Then the GSM Module will reply
mySerial.println("Congrats! You've successfully changed the password: " + readkey);
then the while condition will exit and back to void loop right ? I also try to print Serial.println(readkey); in the void loop so i could check it successfully changed the password and back to void loop.
Now when i text “JJJ”" ON" its only printing in serial and the
  if(textMessage.indexOf(readkey + " ON")>=0){
    Serial.println("LED set to ON");
   textMessage = "";
ignored it . But when i restart the arduino it works fine but i dont want to restart and restartover again, what is the problem guys ?
this is the whole code in void loop .
  if(mySerial.available()>0){
  textMessage = mySerial.readString();
  delay(10);
  if(textMessage.length()>0)
  textMessage=textMessage.substring(textMessage.indexOf("+CMT"));
  textMessage=textMessage.substring(textMessage.indexOf("\n"));
  textMessage.replace("\n","");
  Serial.println(textMessage);
   textMessage = "";
while (textMessage.indexOf(readkey + " SET")>=0){
if (mySerial.available() > 0){
    password = mySerial.readString();
    delay(10);
if(password.length()>0){
password = password.substring(password.indexOf("+CMT"));
password = password.substring(password.indexOf("\n"));
password.replace("\n","");
storePw();
reads();
  mySerial.println("AT+CMGF=1");
  mySerial.println("AT+CMGS=\"+639290584072\"\r");
  delay(100);
   mySerial.println((char)26);
Hello jsteer
Where are the setup and the declarations ?
Regards,
bidouilleelec
As I said, after i changed the readkey using text , I’d Searial.println(readkey); in the void loop so that i know if the data is successfully changed .
This is my whole code bro
 #include <SoftwareSerial.h>
 #include <EEPROM.h>
SoftwareSerial mySerial(9, 10);
String password = "STI";
String textMessage;
String readkey="";
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  delay(5000);
  Serial.println("SIM900 ready...");
  SendMessage();
  reads();
  delay(10);
   textMessage = "";
    delay(10);
storePw();
reads();
  delay(100);
 void SendMessage()
  mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+639290584072\"\r"); // Replace x with mobile number
  mySerial.println("The system is ready");// The SMS text you want to send
  delay(100);
   mySerial.println((char)26);// ASCII code of CTRL+Z
void reads(){
  readkey ="";
  for(int i=0; i<password.length(); i++){
  char a = EEPROM.read(i);
  readkey = readkey+a;
void storePw() {
  EEPROM.write(i, password[i]);
