If statement in switch case
Hey guys,
I am trying to get a robot to go through different situations, depending on how many times the sensor reads a wall. If we just have the switch statements without the if embedded, the switch case will run through its cases. But when we put a if statement that should read if a wall is detected, the distance sensor does not work anymore… what is the problem?
Here is the code:
// motor one
int LeftMotorSpeed = 10;
int LeftMotorFwd = 9;
int LeftMotorRvs = 8;
int distancesensor = 0;
int dist = 0;
int object = 600;
int i = 1;
dist = analogRead(distancesensor);
// set all the motor control pins to outputs
pinMode(LeftMotorSpeed, OUTPUT);
pinMode(LeftMotorFwd, OUTPUT);
pinMode(LeftMotorRvs, OUTPUT);
switch (i){
case 1:
if (dist < object){
//Motor one stop
digitalWrite(LeftMotorFwd, HIGH);
digitalWrite(LeftMotorRvs, LOW);
analogWrite(LeftMotorSpeed, 255);
delay(2000);
i++;
else (dist >= object){
//Motor one stop
digitalWrite(LeftMotorFwd, LOW);
delay(2000);
i++;
case 2:
//Motor one stop
delay(2000);
i++;
case 3:
//Motor1 forward at full speed
digitalWrite(LeftMotorRvs, HIGH);
delay(2000);
i++;
      else (dist >= object)Would this be better as       else if (dist >= object)I wonder ...
And this is expected to do.... what??
Regards, Ray L.
if (dist < object){
Why do you only read the distance once?
What are all those delays doing in there?
(BTW, see what I did with code tags there? You could have done that too)
