Hey folks,
I have a probably simple problem while programming my Arduino Uno R3..
The code is shortened of course, so its just showing the area where I got my problem, but its compiling as it is.
I got a digitalRead reading from a button. The status is printed via the serial interface. So if the button is pressed, it says "pressed". But its saying pressed the whole time, until I get my finger of the button, which is clear to me. But I want to change it. I want it to just show me the "pressed" one time, and then continue with the code. Is that somehow possible?
Thank you in advance (:
const int firstButton = 2;
int first;
pinMode(firstButton, INPUT);
first = digitalRead(firstButton);
if(first) {
Serial.println("pressed");
So, set "first" to false when you print
Thank you my friends. I was able to solve my problem with the state change example, which Delta_G noted at.
For people looking for a similar solution:
int firstState = 0;
int firstLastState = 0;
firstState = digitalRead(firstButton);
if(firstState != firstLastState) {
if(firstState == HIGH) {
Serial.println("First button pressed");
delay(50);
firstLastState = firstState;
Good for getting it working. Now improve it.
Could your int variables be byte instead ? It would save memory, not important here but it could be in a larger program, so it is a good habit to get into.
Have you got a pull down resistor on the input pin or is it floating at an uncertain voltage. Consider using
pinMode(firstButton, INPUT_PULLUP); to activate the internal pullup resistor and change the pushbutton wiring to take the pin LOW when pressed.
What will happen if the switch contacts bounce ? If you don't know what that means then Google "contact bounce"
That makes no sense.
byte currStateOne = LOW;
byte prevStateOne = LOW;
does.
