Hi everyone,
I am currently working on a project that receives data from a web server. I want to then put the results into a float array on my Arduino Mega.
I am able to receive data from the server; however, I was not able to put the results into the array. For some reason, the " if serverAccounts[x] == ','" statement never executes.
What am I doing wrong???
Thank you in advance ![]()
p.s. this is only a snippet of the code, but I am sure that the problem is caused by this part of the file.
void getData(){
  esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
if( esp.find("OK")) {
Serial.println("TCP connection ready");
} delay(50);
String postRequest =
"POST " + uri2 + " HTTP/1.0\r\n" +
"Host: " + server + "\r\n" +
"Accept: *" + "/" + "*\r\n" +
"Content-Length: " + data.length() + "\r\n" +
"Content-Type: application/x-www-form-urlencoded\r\n" +
"\r\n" + data;
String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(postRequest.length() );
if(esp.find(">")) { Serial.println("Sending.."); lcd.clear(); lcd.print("Connecting..."); esp.print(postRequest);
if( esp.find("SEND OK")) { Serial.println("Packet sent");
while (esp.available()) {
String tmpResp = esp.readString();
size_t startOfData = tmpResp.indexOf("Results=");
size_t endOfData = tmpResp.indexOf("CLOSED");
serverAccounts = tmpResp.substring(startOfData+8, endOfData);
Serial.println(tmpResp);
Serial.println(serverAccounts);
Serial.println(serverAccounts.substring(2,5));
for (int x=0; x<= serverAccounts.length();x++){
 if (serverAccounts[x] == ","){
 Â
  size_t endOfNumber = serverAccounts.indexOf(",", x+1);
  String section = serverAccounts.substring(x+2, endOfNumber);
  Serial.print("Section: ");
  Serial.println(section);
  float value = section.toFloat();
  Serial.println(value);
  accounts2[index] = value;
  index+=1;
// close the connection
lcd.clear();
lcd.print("Success!");
esp.println("AT+CIPCLOSE");
