If statement is skipped even though the condition is met!
I have a very long application that deals with a 4G shield and i made a code to parse the incoming data from the shield to the Arduino.
The code is supposed to read what comes from the shield and act upon that.
Reading is done and tested with no problems
The problem is, i have a condition in an if statement that is being met and yet the if statement is being skipped and the software just goes to the else.
Here is the part of the code that parse the data:
SoftwareSerial MYGSM(7, 8); // Define virtual serial port name as MYGSM,Rx is port 7, Tx is port 8
enum parsechecking //PARSING MACHINE WITH DIFFERENT STATES
  todetectmessge,
  toignore,
  workwithit,
  nextworkwithit
byte parsechecking = todetectmessge; //START HERE
char buffer[256];                     // buffer of character
byte pos = 0; //the current position
uint8_t state; //machine inside the loop to send the command once
const uint8_t START = 0;
const uint8_t tochecknetwork = 1;
void resetBuffer()
  memset(buffer, 0, sizeof(buffer));
  pos = 0;
  MYGSM.begin(19200);
  Serial.begin(19200);
  if (state == START)
    Serial.println("we just sent the CSQ");
    MYGSM.println("AT+CSQ");
    //this command is sent to the module to check the connection
    //it return a vule in this form: +CSQ: xx,xx
    // so basically if it's 99,xx OR xx,99 i want to switch to offline
    //because the connection was not established
    state = tochecknetwork;
    Serial.println("WE are reading ");
  else if (state == tochecknetwork)
    while (MYGSM.available())
      const char *checked = MYGSM.read();
      checkparsename(checked); //take the reading from it and parse it
void checkparsename(byte b)
  buffer[pos++] = b;
  if (pos >= sizeof(buffer))
    resetBuffer(); // just to be safe
  // Detailed debugging
  Serial.print("state = ");
  Serial.println(parsechecking);
  Serial.print("pos = ");
  Serial.println(pos);
  Serial.print("buffer = ");
  Serial.println(buffer);
  switch (parsechecking)
    case todetectmessge:
      Serial.println("Detecting");
      if (b == '\n')
        resetBuffer();
      if (pos == 6 && strcmp(buffer, "AT+CSQ") == 0) //this is what was sent
        parsechecking = toignore;
      if (pos == 5 && strcmp(buffer, "+CSQ:") == 0)//this is the responce from the module
        resetBuffer();
        parsechecking = workwithit;
    case toignore:
      Serial.print("Ignoring echoCSQ:  ");
      resetBuffer();
    case workwithit:
      if (b == ',')
        Serial.print("The reciecved signal is:");
        if (pos == 4 && strcmp(buffer, " 99,") == 0)
          Serial.println("it's 99");
          // state = nosignalfound;
          resetBuffer();
          parsechecking = nextworkwithit;
          Serial.println("we can go");
          resetBuffer();
          // state = signalfound;
    case nextworkwithit:
      if (b == '\n')
        Serial.print("In the nextworkwithit:");
        if (pos == 2 && strcmp(buffer, "99") == 0)
          Serial.println("SIGNAL NOT FOUND");
          Serial.println("signal found;");
And i'm sure the conditions are satisfied accourding to the debugging
here is an example output
4:02:06.883 -> WE are reading
14:02:06.883 ->
14:02:06.883 -> state = 0
14:02:06.883 -> pos = 1
14:02:06.883 -> buffer = A
14:02:06.931 -> Detecting
14:02:06.931 ->
14:02:06.931 -> state = 0
14:02:06.931 -> pos = 2
14:02:06.931 -> buffer = AT
14:02:06.931 ->
14:02:06.931 -> pos = 3
14:02:06.931 -> buffer = AT+
14:02:06.976 -> Detecting
14:02:06.976 ->
14:02:06.976 -> state = 0
14:02:06.976 -> pos = 4
14:02:06.976 -> buffer = AT+C
14:02:06.976 ->
14:02:06.976 -> pos = 5
14:02:06.976 -> buffer = AT+CS
14:02:07.023 -> Detecting
14:02:07.023 ->
14:02:07.023 -> state = 0
14:02:07.023 -> pos = 6
14:02:07.023 -> buffer = AT+CSQ
14:02:07.023 ->
14:02:07.023 -> state = 1
14:02:07.023 -> pos = 7
14:02:07.070 -> buffer = AT+CSQ
14:02:07.070 -> Ignoring echoCSQ: AT+CSQ
14:02:07.070 ->
14:02:07.070 -> state = 0
14:02:07.070 -> pos = 1
14:02:07.070 -> Detecting
14:02:07.115 ->
14:02:07.115 -> state = 0
14:02:07.115 -> pos = 2
14:02:07.115 -> buffer =
14:02:07.115 ->
14:02:07.115 -> Detecting
14:02:07.115 ->
14:02:07.115 -> pos = 1
14:02:07.115 -> buffer = +
14:02:07.161 -> Detecting
14:02:07.161 ->
14:02:07.161 -> state = 0
14:02:07.161 -> pos = 2
14:02:07.161 -> buffer = +C
14:02:07.161 ->
14:02:07.161 -> pos = 3
14:02:07.161 -> buffer = +CS
14:02:07.207 -> Detecting
14:02:07.207 ->
14:02:07.207 -> state = 0
14:02:07.207 -> pos = 4
14:02:07.207 -> buffer = +CSQ
14:02:07.207 ->
14:02:07.207 -> pos = 5
14:02:07.207 -> buffer = +CSQ:
14:02:07.253 -> Detecting
14:02:07.253 ->
14:02:07.253 -> state = 2
14:02:07.253 -> pos = 1
14:02:07.253 -> buffer =
14:02:07.253 ->
14:02:07.253 -> pos = 2
14:02:07.253 -> buffer = 1
14:02:07.298 ->
14:02:07.298 -> state = 2
14:02:07.298 -> pos = 3
14:02:07.298 -> buffer = 10
14:02:07.298 ->
14:02:07.298 -> pos = 4
14:02:07.298 -> buffer = 10,
14:02:07.298 -> The reciecved signal is: 10,
14:02:07.344 -> we can go
14:02:07.344 ->
14:02:07.344 -> state = 3
14:02:07.344 -> pos = 1
14:02:07.344 -> buffer = 9
14:02:07.344 ->
14:02:07.344 -> pos = 2
14:02:07.390 -> buffer = 99
14:02:07.390 ->
14:02:07.390 -> state = 3
14:02:07.390 -> pos = 3
14:02:07.390 ->
14:02:07.390 -> pos = 4
14:02:07.390 ->
14:02:07.437 -> In the nextworkwithit:99
14:02:07.437 ->
14:02:07.437 -> signal found;
14:02:07.437 ->
You see this singal found, it shouldn't be there!!!!
The buffer contained 99 at Pos=2 just like the condition at the if statement
Can anyone tell what's wrong here?
Also, i tried replacing the strcmp(buffer, "99") == 0 with things like saving the buffer into a const char and then compare that char to the 99, For example:
    if (b == '\n')
      const char *toconcider = buffer;
      Serial.print("the toconcider is:");
      Serial.println(toconcider);
      if (toconcider == '99')
        Serial.println("state = nosignalfound;");
        Serial.println("state = signalfound;");
i still had the same problem
Just serial print state and start right before the if statement. There doesn’t seem to be enough code for us to work out the values
My problem is right here
as you can see, these outputs match this condition
and yet the program is skipping it and going to the else statement right away
My guess would be that the condition (b == '\n') does not hold. Can you also print this value to your debug log?
Where did the new line come from? Is it in buffer say "99\n" ?
It does, or else this wouldn't be here
buffer is only printing this
I think it should have \n
is there anyway to show that ?
Also i tried changing the code to this:
      if (b == '\n')
        if (pos == 2 && strcmp(buffer, "99\n") == 0)
still same
try:
 if (pos == 2 && strncmp(buffer, "99", 2) == 0)  // strncmp
Which indeed seems to be missing in that iteration.
I see what you mentioned here,
I modified the code with @6v6gt comment
too
So here is the combined one,
        resetBuffer();
        state = nothing;
      else if (pos == 2 && strncmp(buffer, "99", 2) != 0)  // strncmp
        resetBuffer();
My concern now is that both functions are being called, and later i want to act upon one condition only
see the serial output:
17:06:16.281 -> state = 3
17:06:16.281 -> pos = 1
17:06:16.281 -> buffer = 9
17:06:16.281 -> In the nextworkwithit:9
17:06:16.281 ->
17:06:16.327 -> pos = 2
17:06:16.327 -> buffer = 99
17:06:16.327 -> In the nextworkwithit:99
17:06:16.327 -> SIGNAL NOT FOUND
17:06:16.327 ->
17:06:16.327 -> state = 3
17:06:16.327 -> pos = 1
17:06:16.373 -> In the nextworkwithit:
17:06:16.373 ->
17:06:16.373 -> state = 3
17:06:16.373 -> pos = 2
17:06:16.373 -> buffer =
17:06:16.373 ->
17:06:16.420 ->
17:06:16.420 -> signal found;
17:06:16.420 ->
17:06:16.420 -> state = 3
17:06:16.420 -> pos = 1
17:06:16.420 -> buffer =
17:06:16.420 -> In the nextworkwithit:
17:06:16.420 ->
17:06:16.467 -> pos = 2
17:06:16.467 -> buffer =
17:06:16.467 ->
17:06:16.467 -> In the nextworkwithit:
17:06:16.467 ->
17:06:16.467 -> signal found;
17:06:16.467 ->
17:06:16.467 -> state = 3
17:06:16.467 -> pos = 1
17:06:16.467 -> buffer = O
17:06:16.513 -> In the nextworkwithit:O
17:06:16.513 ->
17:06:16.513 -> state = 3
17:06:16.513 -> pos = 2
17:06:16.513 -> buffer = OK
17:06:16.513 -> In the nextworkwithit:OK
17:06:16.560 -> signal found;
17:06:16.560 ->
17:06:16.560 -> state = 3
17:06:16.560 -> pos = 1
17:06:16.560 -> buffer =
17:06:16.560 -> In the nextworkwithit:
17:06:16.560 ->
17:06:16.606 -> pos = 2
17:06:16.606 -> buffer =
17:06:16.606 ->
17:06:16.606 -> In the nextworkwithit:
17:06:16.606 ->
17:06:16.606 -> signal found;
17:06:16.606 -> GOOD JOB
17:06:16.653 -> GOOD JOB
these GOODJOB outputs are coming from state = nothing, i put it up in the loop
but what concerns mee now is that i still get this
Okay settled already, apparently, i just had to add this line only:
because the buffer kept sending data and i had to do something with it
Any way, thanks to all for helping
I will post a summary of solution next comment
It is important to analyse the whole feedback coming from the module before designing a parsing function,
The solution to my issue was this:
#include <SoftwareSerial.h>
enum parsechecking
  todetectmessge,
  toignore,
  workwithit,
  nextworkwithit
const uint8_t nothing = 2;
void resetBuffer()
  pos = 0;
  MYGSM.begin(19200);
  if (state == START)
  else if (state == nothing) {
    Serial.println("GOOD JOB");
  buffer[pos++] = b;
      if (b == '\n')
        resetBuffer();
        resetBuffer();
    case toignore:
      resetBuffer();
    case workwithit:
      if (b == ',')
          resetBuffer();
          resetBuffer();
        resetBuffer();
//since the buffer might still have data coming,
//i need to analyse them and hence sending it back to the initial stage to detect the type
        state = nothing;
        resetBuffer();
Just for your future reference, in order to avoid these scenarios, when printing data I would suggest encapsulating the values.
For example, like this:
Serial.printf("buffer = '%s'\n", buffer);
or
Serial.printf("buffer = {%s}\n", buffer);
Whatever you like.
This way, you could catch much earlier that extra new-line character in your buffer :slight_smile:
