If statement issue
Hello, I am a little confused now because I'm not sure what am I doing wrong.
I want to control 2 DC motors with 4 buttons (Motor1 left, Motor1, right, Motor 2 left, Motor2 right). Everything works as should except one 'If' statement, where the motor keeps going instead of stop after a second, like in other cases. I've already switched motors, then buttons, then pins on board, and it is the same. When I comment out the problematic 'IF', the rest 3 works perfectly.
The issue I have is with Moto2down part.
Can someone have a look and help me here, please?
(for motor controls I'm using TB6612FNG)
//Moto 1
int motor1pin1 = 2;
int motor1pin2 = 3;
//Moto 2
int motor2pin1 = 4;
int motor2pin2 = 5;
//buttons
int moto1up = 6;
int moto1down = 7;
int moto2up = 8;
int moto2down = 11;
bool moto1up_state = 0;
bool moto1down_state = 0;
bool moto2up_state = 0;
bool moto2down_state = 0;
  pinMode(motor1pin1, OUTPUT);
  pinMode(motor1pin2, OUTPUT);
  pinMode(motor2pin1, OUTPUT);
  pinMode(motor2pin2, OUTPUT);
  pinMode(moto1up, INPUT_PULLUP);
  pinMode(moto1down, INPUT_PULLUP);
  pinMode(moto2up, INPUT_PULLUP);
  pinMode(moto2down, INPUT_PULLUP);
  //pwm
  pinMode(9,  OUTPUT);
  pinMode(10, OUTPUT);
  moto1up_state = digitalRead(moto1up);
  moto1down_state = digitalRead(moto1down);
  moto2up_state = digitalRead(moto2up);
  moto2down_state = digitalRead(moto2down);
if (moto1up_state == LOW){ // Motor 1 up
  analogWrite(9, 100); //ENB pin
  digitalWrite(motor1pin1, HIGH);
  digitalWrite(motor1pin2, LOW);
if (moto1down_state == LOW){ // Motor 1 down
  analogWrite(9, 100); //ENA   pin
  digitalWrite(motor1pin1, LOW);
  digitalWrite(motor1pin2, HIGH);
if (moto2down_state == LOW){ // Motor 2 down
  analogWrite(10, 100);
  digitalWrite(motor2pin1, LOW);
  digitalWrite(motor2pin2, HIGH);
if (moto2up_state == LOW){ // Motor 2 up
  digitalWrite(motor2pin1, HIGH);
  digitalWrite(motor2pin2, LOW);
else {
you have 4 if statements. which is the problem?
just one has an else condition that presumably stops the motors when the moto2up input is not LOW
but if you just momentarily press any of the inputs, that else condition should be true ... so i'm not clear what the problem is
I'm not sure, but is there an error in your last line?
I suppose, it sould be:
Thank you so much! The problem was there. It works now.
Have a nice day!
Problem was in the last line, where I had Moto1pin2 instead of Moto2pin2
