If statement makes ESP8266 reboot
Hi
When I run if statement the MCU reset the second I press the button
I have tried
unsigned long startTime = millis();
and
int startTime = millis();
Same result
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
Exception (4):
epc1=0x40201a46 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffe40 end: 3fffffd0 offset: 0160
3fffffa0:  3fffdad0 00000000 3ffeeedc 3ffeef08
3fffffb0:  3fffdad0 00000000 3ffeeedc 4020450c
3fffffc0:  feefeffe feefeffe 3fffdab0 40100d95
<<<stack<<<
Code:
int switchTare       = D1;    // select the input pin for the switch
int switchTareValue  = 0;
Void loop()
  if (digitalRead(switchTare) == HIGH) {
      while (digitalRead(switchTare) == HIGH) {
      if (millis() - startTime > 7000) {
         //tare();                                  // call function tare
        Serial.println("Calibrate millis");
Any idea why mcu crash?
you are blocking the code with your while loop
add a yield(); to give the esp a chance to perform it's background tasks.
If you don't know how - make a full compileable example we can put in the IDE and make it run on our devices.
Thanks!!!
This code compiles for me
//card node mcu 1.0
const int switchTare = D2;
  pinMode(switchTare, INPUT);
      if (millis() - startTime > 7000) {              // tid knappen må holdes nede før komando kjøres
        //functionTare();                               // call function tare
        Serial.println("tare mills");
add a yield()
      yield();
doesn't throw an exception any more.
Doesn't print neither because you missed a Serial.begin();
Thanks, I did not have a qlue about the yield() function.
But you did, and it worked!!!
:slight_smile:
SOLUTION as a function
(update 2)
I made this like a function because I have 4 switches (read relays).
tare
calibrate
alarm
reset
All 4 is functions, all switches except alarm is NO
Example
int switchTareValue  = 0;     // variable to store the value coming from the sensor
void setup(){
// check if switchTare is pressed
       buttonWait(switchTare, buttonPressTime, functionTare, HIGH);    // wait for HIGH state
//Function
void buttonWait(int switchPin, int waitTime, void (*function)(), bool state) {  // true for HIGH, false for LOW
  pinMode(switchPin, INPUT);
  if (digitalRead(switchPin) == state) {
    while (digitalRead(switchPin) == state) {
      if (millis() - startTime > waitTime) {
        (*function)();  // call the function pointed to by the function pointer
      yield(); // allow other tasks to be executed
it's up to you but
a) I suspect your sketch will not compile - {} are not correct, missing variables, ...
b) your code is still blocking. Do a refactoring of your code and get rid off your while
may be you should google for "Finite State Machine" and apply that to your program.
Hi @noiasca thanks for helping me.
The code is part of a bigger project so there can be missing parts in my function sample.
I have built a bee monitor, 150 kg scale (with auto calibration), temp, humidity sent over LoRa to a receiver (ttgo lora oled) that again sends data to cayenne and to a web server.
My sketch it compiles and when I press button for 5 sec the function is running and then goes back to the void loop.
I'm not an expert, a bit google, a bit old basic and fortran 30-40 years ago and a skilled son. And I have time, started on this code 1 year ago :wink:
I'm sure the code can be optimized, but that is a level I'm not capable off.
I'm happy as long as it runs, what it does per today!
If you have specifics in code I appreciate your effort to help me further.
M
