if statement , making a pin high for certain amount of time
hello
I need a code for if statement that makes the pin hight for a certain amount of time if the condition has been met
for example
if(x>400 )
  digitalWrite(pin, HIGH);// i need this to be high for t amount of time
 }else{
  digitalWrite(pin, LOW);
thanks
Start by detecting when x becomes greater than 400 rather than when it is greater than 400. See the StateChangeDetection example in the IDE
When x becomes greater than 400 save the value of millis() as the start time. Then, each time through loop() compare the current value of millis() with the start time and if the required period has elapsed take whatever action you need
thanks for your reply
in my code 400 is a sensor reading, I can't work out how to change the bottom example to the analog reading of a sensor
Something like this (untested)
  previousValue = currentValue;  //save the previous value
  currentValue = analogRead(sensorPin);
  if (currentValue > 400 && previousValue <=400 && !timing)  //the value has become greater than 400
    timing = true;
    startTime = millis();
  if (timing && millis() - start time >= period)  //time's up
    timing = false;
NOTE : there is work to do on the code such as declaring variables
thanks
I will try to work on it
UKHeliBob:
why should I do "Start by detecting when x becomes greater than 400 rather than when it is greater than 400." ?
in another word
what would be a problem if i do like this ?
 s_currentValue = analogRead(A0);
        if (s_currentValue > 400 && !timing)
          timing = true;
          digitalWrite(pump, LOW);
        if (timing && millis() - startTime >= period)  //time's up
          timing = false;
          digitalWrite(pump, HIGH);
moeinipharmd:
why should I do “Start by detecting when x becomes greater than 400 rather than when it is greater than 400.” ?
Because you said:
“I need a code for if statement that makes the pin hight for a certain amount of time if the condition has been met”
larryd:
Because you said:
"I need a code for if statement that makes the pin hight for a certain amount of time if the condition has been met"
I think it is because you don't want to stuck with a relay that keeps going open and close continuously because it wants to maintain exactly lower or higher than the threshold
am I right ?
am I right ?
That depends on your application and in the case of your original post you were quite clear
If you were to detect when the condition is currently true rather when it became true that would not meet your requirement
UKHeliBob:
That depends on your application and in the case of your original post you were quite clearIf you were to detect when the condition is currently true rather when it became true that would not meet your requirement
it was just a case of bad english on my part :))
So what is it that you really want to do ?
