if statement not displaying the value I need.
When the value of the variable "torque" is less than zero(because the value is negative), the LCD and serial will display the value zero instead.
I used this code but it did NOT equate/display the value zero for the variable "torque" in the LCD and serial, if the value of "torque" is less than zero.
if (torque < 0)
  torque == 0;
Serial output. RPM is ok
RPM , torque , voltage from loadcell
0 , -6.49 , 0.05
0 , -6.30 , 0.11
0 , -6.15 , 1.16
0 , -5.94 , 1.52
My target is that when 'torque' is less than(negative) zero it must display its value as zero.
Something like this in the serial.
0 , 0 , 0.05
0 , 0 , 0.11
0 , 0 , 1.16
0 , 0.2 , 1.52
Why did it not displaying the value zero and what is the right way coding it?
Entire sketch:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 7); //LiquidCrystal(rs, rw, enable, d4, d5, d6, d7)
int backLight = 13;
const int hallPin=2;  //RPM:
const unsigned long sampleTime=3000; //RPM:6000(10)
const int maxRPM = 1700;  //RPM:
const int numReadings = 25;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int voltage = 0;                // the average
int voltageSmooth;
int torque;
int sensorValue1 = analogRead(A0);
    pinMode(hallPin,INPUT); //RPM:
    lcd.begin(20, 4);
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
  pinMode(9, OUTPUT);  // D9 to LCD Pin 3
  analogWrite(9, 50);   // set contrast
    // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
   int rpm=getRPM(); //RPM:
   // subtract the last reading:
  total= total - readings[index];
  // read from the sensor:
  readings[index] = analogRead(sensorValue1);
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
index = 0;
  // calculate the average=voltage:
  voltageSmooth = total / numReadings;
 float voltage = voltageSmooth * (5.0 / 1023.0);
 float torque = (0.143*(voltage*voltage)+0.306*voltage-0.73)*2.2*4.13;  //(voltage - 1.6) / 0.985 * 2.2 * 4.13;
 if (torque < 0)
  torque == 0;
   lcd.clear();
  lcd.setCursor(0, 0);
    lcd.print("DIGITAL DYNAMOMETER");
  lcd.setCursor(0, 1);
    lcd.print("TORQUE");
  lcd.setCursor(6, 1);
    lcd.print(":");
    lcd.print(torque, 2);
    lcd.print(" lbf.in");
  lcd.setCursor(0, 2);
    lcd.print("RPM");
  lcd.setCursor(6, 2);
    lcd.print(":");
    lcd.print(rpm,DEC);
    lcd.print("rpm");
  lcd.setCursor(0, 3);
    lcd.print("TEMP");
  lcd.setCursor(6, 3);
    lcd.print(":");
    lcd.print("NA_");
    lcd.print("*C");
  Serial.print(rpm,DEC);
  Serial.print(" , ");
  Serial.print(torque, 2);
  Serial.print(voltage, 2);
int getRPM() //RPM:
  // sample for sampleTime in milliseconds
  int count=0; //RPM:
  boolean kflag=HIGH; //RPM:
  unsigned long currentTime=0; //RPM:
  unsigned long startTime=millis(); //RPM:
  while (currentTime<=sampleTime) //RPM:
    if (digitalRead(hallPin)==HIGH) //RPM:
      kflag=HIGH; //RPM:
    if (digitalRead(hallPin)==LOW && kflag==HIGH) //RPM:
      count++; //RPM:
      kflag=LOW; //RPM:
    currentTime=millis()-startTime; //RPM:
  int count2rpm = int(60000./float(sampleTime))*count; //RPM:
  return count2rpm; //RPM:
 torque == 0;
Does not assign zero to the variable
Hmm ok. Thx for the reply :slight_smile:
So how can I set the output value to zero if the value is less than for "torque"?
torque = 0;
Double == is for comparing. Single for assigning.
== is an equality operator, which returns true if the 2 operands are equal.
= is an assignment operator
ie
int a = 4;
int b = 4;
int c;
if( a == b )
  // a is equal to b
  // assign a value to c...
  c = 0;
What you're after is:
torque = 0;
Will this work?
if (torque < 0.00)
  torque = 0.00;
Those this say if value of "torque" is less than zero, it will assigned the value of 0.00 ?
is these better?
Not really, torque is an int, therefore there is no need to assign a value with 2 decimal place precision.
if (torque < 0 )
  torque = 0;
will suffice.
Tried your code it worked! Thanks.
Also thanks septillion and AWOL for your answers. :slight_smile:
tammytam:
if (torque < 0 )
  torque = 0;
will suffice.
