If statement not working
I have a sketch that the if statement isn’t working correctly. I have a global variable roundNum and it is set in one part of the code to 2 but when i run the sketch it doesn’t seem to work. I ran it in Simulator for Arduino and got some weird results. The test for if (roundNum==0) will revert to true if I set roundNum to 2 in the variable window so I think that it might be doing the same in the real Arduino.
If I set roundNum to 2 immediately before the test then it works…maybe my variable is never getting set to 2? I don’t see how it wouldnt,
#define DEBOUNCE 10  // button debouncer, how many ms to debounce, 5+ ms is usually plenty
byte buttons[] = {21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40}; // the pin #s of the buttons
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
byte LEDs[]={0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 15, 16, 17, 18, 19, 20}; //the pin #s of LED pins
boolean LEDState[NUMBUTTONS]={}; //keep track of LED state Set all to False
int LEDOn=0; //to keep track of how many LEDs are currently lit....Do we need? check array?
byte combo1[]={0,1,2,3,4}; // The buttons that make up the combination in the first puzzle
byte combo2[]={12,13,14,15}; // The buttons that make up the combination in the second puzzle
// we will track if a button is just pressed, just released, or 'currently pressed'
volatile byte pressed[NUMBUTTONS]={}, justpressed[NUMBUTTONS]={}, justreleased[]={};
volatile byte i;
byte roundNum=0;
// Set LEDs pins as out put and turn off
  for(i=0; i < NUMBUTTONS; i++)
    pinMode(LEDs[i], OUTPUT);
    digitalWrite(LEDs[i], LOW);
 // Make button pins as input & enable pull-up resistors on switch pins
  for (i=0; i < NUMBUTTONS; i++)
    pinMode(buttons[i], INPUT_PULLUP);
  //set up trigger pin
  pinMode(41, OUTPUT);
  digitalWrite(41, LOW);
  // Run timer2 interrupt every 15 ms
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20; //1024 prescaler
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime)// we wrapped around, lets just try again.. do we need with timer of?
     lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) // not enough time has passed to debounce do we need with timer of
    return;
  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++)
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    if (currentstate[index] == previousstate[index]) // two readings the same 10ms apart
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) // just released....Is this needed?
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // Button state has changed so update button status
      previousstate[index] = currentstate[index];   // stores last state to see if it stays the same after debounce period
  byte numOn=0;
  byte comboCheck=0;
  check_switches();
  if (roundNum==0) //this is always testing true????
    for (i = 0; i < 12; i++)//only check first 12 buttons
      if (justpressed[i])
      justpressed[i] = 0;
      LEDState[i]=!LEDState[i]; //toggle LED Status
      digitalWrite(LEDs[i], !digitalRead(LEDs[i])); //Toggle LED
      for (byte j =0; j < 12; j++) //count the number of LEDs lit
        if (LEDState[j])
          numOn++;
      if (numOn==5)
        for (byte k=0; k<5; k++)
          if (LEDState[combo1[k]])
          comboCheck++;
        if (comboCheck==5)// Correct combo reached
          roundNum=2; //is this ever happening?
          else // wrong combo
          for (byte k = 0; k< 12; k++)
            digitalWrite(LEDs[k],LOW);
            LEDState[k]=false;
  if (roundNum==2)
    for (byte j =12; j < 20; j++) //count the number of LEDs lit
        if (LEDState[j])
          numOn++;
      if (numOn==4)
        for (byte k=0; k<4; k++)
          if (LEDState[combo2[k]])
            comboCheck++;
          if (comboCheck==4)// Correct combo reached
             digitalWrite(41,HIGH);
          else // wrong combo
            for (byte k = 12; k< 20; k++)
              LEDState[k]=false;
Still with the useless initialization sections…
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
We REALLY do not need to see commented out crap.
          Serial.print("roundNim WAS set to 2!"); // Why not find out?
Print the value of comboCheck immediately after the line comboCheck ++;
...R
Paul,
I was tired and forgot to clean the code up...
Robin,
Thanks.... Well I was relying on the simulator to work correctly for debugging purposes, but it didn't. So I put in a bunch of print statements and found the problem.
Thanks for your help
