if statement not working
why i cant specify two pins for output?
also, if statements are not working properly here.
pinMode (13, OUTPUT);
pinMode (12, OUTPUT};
  int a;
  int b;
  a = analogRead(A1);
  b = analogRead(A2);
   float va = a * (5.0/1023.0);
   float vb = b * (5.0/1023.0);
  if (va > 4)
    digitalWrite(13, HIGH);
  else if (vb > 4)
    digitalWrite(12, HIGH);
    digitalWrite(13, LOW);
    digitalWrite(12, LOW);
expected output:
when A1 get 5v, led on 13 go high, 12 go low
when A2 get 5v, led on 13 go low, 12 go high
observed output:
when A1 get 5v, led on 13 go high, 12 go high
when A2 get 5v, led on 13 go high, 12 go high
why it is happening?
also, im getting an error
Arduino: 1.6.3 (Windows 7), Board: "Arduino Uno"
Build options changed, rebuilding all
sketch_jul14a.ino: In function 'void setup()':
sketch_jul14a.ino:5:20: error: expected ')' before '}' token
sketch_jul14a.ino:5:20: error: expected ';' before '}' token
sketch_jul14a.ino: At global scope:
sketch_jul14a.ino:6:4: error: expected declaration before '}' token
Error compiling.
  enabled in File > Preferences.
should be
pinMode (12, OUTPUT);
dannable:
should be
thanks i did it now, no errors! but still expected and observed out[ut is different why?
Print out the values of va and vb using serial monitor and see if they are what you expect.
  if (va > 4)
  else if (vb > 4)
Your indentation assumes you want those 2 last lines to be executed within the else?
If that is your intent, you need to bracket that block, otherwise only a single line will be called as part of that else:
if (va > 4)
else if (vb > 4)
Also in the if() and the else if(), only 1 pin is set, the other pin will be whatever you left it as.
Also, since va and vb are float data types, it's better style to write:
if (va > 4.0)                            // Note trailing zero
else if (vb > 4.0)
as it documents that the if expression is on a floating point number.
