Hello. Im new here not sure if im in the right place but hopefully.
Im doing motor rotator with encoder and code works basically like it should. Only thing is that the encoder direction does not change.
I have lcd shield with buttons. When I press right/left button, motor starts turning and encoder starts reading direction, but the direction does not change. If I press right/left again then I see new value.
// blinks once per second to indicate healthy main loop; (13) for built-in LED on UNO
#define HEARTBEAT_LED (13)
// analog input pin for FORWARD power reading
#define FWD_PIN (14)
// analog input pin for REFLECTED power reading
#define REF_PIN (15)
// REQUIRED: numeric limits for SWR hardware sensor
// define power limits (W); this is the power reading corresponding
// to a full-scale A/D reading; to report the power as a percentage
// of full scale, set this to 100.0.
#define FULL_SCALE_FORWARD (20.0)
#define FULL_SCALE_REFLECTED (20.0)
// MINIMUM A/D for SWR - this is the minimum A/D reading that will produce an
// SWR != 1.0; this helps to prevent unnecessarily high SWR readings at low
// power levels where there is insufficient A/D resolution to make accurate
// SWR calculations. This value is the RAW value used as a minimum FORWARD
// power limit. Below this RAW value, the SWR will be reported as 1.0.
#define MIN_POWER (5)
// Serial Port - assign a specific hardware port to be the interface to
// the host; by default, the USB connection on most boards is 'Serial',
// which is also the hardware TTL serial port on the UNO board. Make
// sure to only select ONE option.
// OPTIONAL: select host serial port
// default for most boards' USB port
#define HostSerial Serial
// default for Leonardo UART, and second MEGA port
//#define HostSerial Serial1
// default for third MEGA port
//#define HostSerial Serial2
// default for fourth MEGA port
//#define HostSerial Serial3
// the 'baud rate' for the serial port
#define SerialRate (9600)
// OPTIONAL: enable persistence of settings
// If this is set to 'true', the firmware will store the values of 'alpha'
// into the EEPROM whenever the value is changed by user commands.
#define PERSIST_SETTINGS false
// Items below this level are OPTIONAL, and can enable display and lighting
// features that were shown as examples in the website. You can use these
// examples as-is, or you can add your own display options
// OPTIONAL: Enable LED bar graph for SWR; LED pin definitions below
#define SWR_BAR_GRAPH false
#if SWR_BAR_GRAPH == true
#include "LightBar.h"
// BAR - Configuration for the 'soft' bar graph (if enabled)
// For each LED in the bar, you will need to specify a
// threshold and digital output pin number (use A# macros
// for analog pins), and an inversion flag, which should
// probably always be false.
// specify the total number of bar elements
const int BarLength = 10;
// specify the configuration for the individual elements
const LightBarItem barItems[BarLength] = {
// GREEN LEDs
{ 1.01, 2, false },
{ 1.25, 4, false },
{ 1.50, 5, false },
{ 1.75, 6, false },
// YELLOW LEDs
{ 2.00, 7, false },
{ 2.33, 8, false },
{ 2.66, 9, false },
// RED LEDs
{ 3.0, 10, false },
{ 4.0, 11, false },
{ 5.0, 12, false },
// OPTIONAL: Enable PWM follower, to control LED bar brightness using a
// hardware potentiometer
#define SWR_BAR_FOLLOWER false
#if SWR_BAR_FOLLOWER == true
#include "FollowPWM.h"
// PWM Brightness Control - if you have enabled SWR_BAR_FOLLOWER, this
// will set up a 'PWM follower' that will adjust a PWM output according
// to the value of an A/D input. You can connect a potentiometer to an
// A/D input, and the output PWM value will follow the A/D voltage at
// runtime. You can use this on the common side of the LEDs of your
// bar graph to control their brightness. CAUTION: Make sure that you
// don't consume too much current on the PWM pin; if you need more net
// current than the PWM line can supply, use a buffer transistor.
// PWM follower (output pin, input pin)
FollowPWM brightness(3, 5);
#endif // SWR_BAR_FOLLOWER
#endif // SWR_BAR_GRAPH
// OPTIONAL: Enable serial 7-segment display
#define SERIAL_SEGMENTED_DISPLAY false
// 7-segment SWR display support
#if SERIAL_SEGMENTED_DISPLAY == true
#include <SoftwareSerial.h>
#include "SegmentSWR.h"
// Serial 7-Segment Display Support - this is an example of a digital
// display for showing SWR.
SegmentSWR segment(7, 8); // 7-segment object (rx pin, tx pin)
#endif // SERIAL_SEGMENTED_DISPLAY
// OPTIONAL: Enable display/OLED character display
// Set this to 'true' to enable 16x2 display; otherwise leave 'false'; if set
// to 'true', you will need to configure a display object, below.
#define ENABLE_DISPLAY true
#if ENABLE_DISPLAY == true
// Configure display
// Add a 'display' object below. Examples are provided for standard display and
// OLED displays in 16x2 format, using parallel interface.
// You can use types other than 'LiquidCrystal' as long as the display object
// is called 'display' and implements the same interface as the 'LiquidCrystal'
// type.
// display example
// This example is for a 16x2 display display connected to D6 through D12, using
// 4-bit data transfer mode.
#include <LiquidCrystal.h>
//display pin to Arduino
const int pin_RS = 8;
const int pin_EN = 9;
const int pin_d4 = 4;
const int pin_d5 = 5;
const int pin_d6 = 6;
const int pin_d7 = 7;
const int pin_BL = 10;
LiquidCrystal display( pin_RS, pin_EN, pin_d4, pin_d5, pin_d6, pin_d7);
int R = 0;
int U = 0;
int D = 0;
int L = 0;
// OLED example
// This example uses the AdaFruit enhanced Adafruit_CharacterOLED type
// that is optimized for OLEDs. This type works with both AdaFruit and
// SparkFun displays based on the RS0010 chip.
// See this hookup guide for an example:
// https://learn.sparkfun.com/tutorials/oled-display-hookup-guide/all
// This is the display type used in the web article.
//#include <Adafruit_CharacterOLED.h>
//Adafruit_CharacterOLED display(OLED_V2, 6, 7, 8, 9, 10, 11, 12);
// Configure display size (default is 16x2)
#define DISPLAY_ROWS (2)
#define DISPLAY_COLS (16)
// Backlight - set this to 'true' if your display supports a
// 'setBacklight' option and you want to enable
// the backlight; otherwise leave this set to 'false'
#define DISPLAY_BACKLIGHT false
#endif // ENABLE_DISPLAY
// ================== END OF CONFIGURATION SETTINGS ==================
// The version string
#define VERSION_DATE "20160920b"
#define VERSION_STRING "MeterSWR 1.0 (beta-" VERSION_DATE ")"
// local headers
#include "Elapsed.h"
#include "Heartbeat.h"
#include "Bounce2.h"
#include "SWR.h"
#include "utils.h"
// Constants and Globals
// Maximum Arduino A/D reading; used only to scale the power readings.
const int ARDUINO_AD_MAX = 1023;
// maximum auto-poll interval (msec)
const int MaxAutoPoll = 1000;
// compute scaling constants for power readings
const float FORWARD_SCALE = (float)FULL_SCALE_FORWARD / (float)ARDUINO_AD_MAX;
const float REFLECT_SCALE = (float)FULL_SCALE_REFLECTED / (float)ARDUINO_AD_MAX;
const uint16_t SegmentUpdateInterval = 500; // msec between segmented display updates
unsigned long lastSegment = 0; // used to track the update interval
#endif
const uint16_t BrightnessUpdateInterval = 500; // set the msec between follower control A/D readings
unsigned long lastBrightness = 0; // used to track the update inteval
#endif
const uint16_t DisplayUpdateInterval = 150; // set the msec between follower control A/D readings
unsigned long lastDisplay = 0;
#endif
// the light bar
LightBar Bar(barItems, BarLength);
#endif
// the SWR calculator
SWR swr(FWD_PIN, REF_PIN);
// a string to hold incoming data
String inputString;
// and another for command data
String cmdText = "";
// command parsing
String command = "";
String argument = "";
// whether the string is complete
boolean inputReady;
// maximum string lengths
const int InputLength = 16;
const int CommandLength = 16;
const int BufferLength = 24;
// I/O buffer
char ioBuffer[BufferLength];
#ifdef CMD_LED
// the last RX data from the host
unsigned long lastRxData;
bool lastCmdLED = false;
#endif
// echo USB RX data back to host
bool echo = false;
// currently parsing a command
bool cmd = false;
// autopolling
unsigned autoPoll = 0;
unsigned long lastPoll = 0;
bool autoRaw = false;
// global timer (amoritize clock read to one/loop)
unsigned long now;
#if PERSIST_SETTINGS == true
#include "persist.h"
#endif
// UpdateDisplays() - update user displays, if any.
// This is where you can update any bar graphs, digital displays, etc.
// to show readings to the user.
static void UpdateDisplays() {
// NOTE: the 'swr' object will always be updated immediately prior
// to calling UpdateDisplays(), so we can use it directly to
// get the values we need.
// Current SWR is read using swr.Value()
// Current Power Forward is read using swr.Forward()
// Current Power Reflected is read using swr.Reflected()
// refresh the clock
unsigned long now = millis();
// EXAMPLE: update bar graph
Bar.Update(swr.Value());
if (Elapsed(now, lastBrightness) >= BrightnessUpdateInterval) {
brightness.Process();
lastBrightness = now;
#endif
#endif
// EXAMPLE: update segmented display
// update 7-segment display
if (Elapsed(now, lastSegment) >= SegmentUpdateInterval) {
segment.Update(swr.Value());
lastSegment = now;
#endif
// Example: line 1 - display the forward power level
display.setCursor(0, 0);
uint8_t count = 0;
// the label
display.print(strcpy_P(ioBuffer, PSTR("F: ")));
count += strlen(ioBuffer);
// the number
FormatFloat(ioBuffer, sizeof(ioBuffer), swr.Forward());
display.print(ioBuffer);
// spaces
for (uint8_t i = count; i < (DISPLAY_COLS - 4); ++i) {
display.print(' ');
// SWR label
display.print(strcpy_P(ioBuffer, PSTR("SWR ")));
// Example: line 2 - display the reflected power and SWR
display.setCursor(0, 1);
// the label
count = 0;
snprintf(ioBuffer, sizeof(ioBuffer), strcpy_P(ioBuffer, PSTR("R: ")));
// the number
FormatFloat(ioBuffer, sizeof(ioBuffer), swr.Reflected());
// spaces and SWR value
FormatFloat(ioBuffer, sizeof(ioBuffer), swr.Value());
for (uint8_t i = count; i < (DISPLAY_COLS - strlen(ioBuffer)); ++i) {
display.print(' ');
#endif
// OPTIONAL: update other items
// If you have added other display hardware, perform updates to
// it here.
#include <Encoder.h>
Encoder windvane(21, 20);
// setup()
display.begin(16, 2);
display.print("Select up / down");
display.print("Rotate <-- -->");
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
// start the serial port
HostSerial.begin(SerialRate);
// allocate string storage
inputString.reserve(InputLength);
cmdText.reserve(CommandLength);
// prime the command pipeline with a version command
inputString = strcpy_P(ioBuffer, PSTR("#VERSION;"));
inputReady = true;
// the A/D inputs
pinMode(FWD_PIN, INPUT);
pinMode(REF_PIN, INPUT);
// configure the SWR algorithm
swr.MinPower(MIN_POWER);
swr.ScaleForward(FORWARD_SCALE);
swr.ScaleReflected(REFLECT_SCALE);
// initialize the bar graph
Bar.Initialize();
#endif
// initialize the 7-segment display
segment.Initialize();
#endif
// initialize the display
display.begin(DISPLAY_COLS, DISPLAY_ROWS);
display.clear();
display.home();
display.clear();
display.home();
#if DISPLAY_BACKLIGHT == true
// enable backlight
display.setBacklight(HIGH);
#endif
// print banner including version number
// strcpy_P(ioBuffer, PSTR("OH1CJO"));
// const uint8_t x = (DISPLAY_COLS - strlen(ioBuffer)) / 2;
display.print("SWR UP - LED DWN");
display.print("Rotate <--- --->");
// pause to let user actually *read* the banner
delay(1500);
#endif
// set up the HB LED
HeartbeatSetup();
// load EEPROM settings
load_eeprom();
#endif
int old_pos = windvane.read();
const char wd[][17]={{"POHJOiNEN "},{"KOILLINEN "},{"ITA "},{"KAAKKO "},{"ETELA "},{"LOUNAS "}, {"LANSI "},{"LUODE "}};
int x;
x = analogRead (0);
if (x < 60) {
R = 1; //Right;
display.clear();
display.print ("Rotating right");
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 100); //Spins the motor on Channel A at full speed
U = 0;
D = 0;
L = 0;
int e = windvane.read();;
display.print(wd[abs(e % 2400)/280]);
else if (x < 200) {
U = 1; //Up;
display.clear();
display.print ("SWR / Power?");
display.print ("Press Select");
R = 0;
D = 0;
L = 0;
else if (x < 400) {
D = 1; //Down;
display.clear();
display.print ("LED CONTROL");
R = 0;
U = 0;
L = 0;
else if (x < 600) {
L = 1; //Left;
display.clear();
display.print ("Rotating left");
digitalWrite(12, LOW); //Establishes backward direction of Channel A
analogWrite(3, 100); //Spins the motor on Channel A at half speed
R = 0;
U = 0;
D = 0;
else if (x < 800) {
if (R == 1) {
display.clear();
display.print ("Motor STOP");
analogWrite(3, 0); //Spins the motor on Channel A at full speed
R = 0;
// Your code here
if (U == 1) {
display.clear();
display.print ("SWR / POWER");
display.print ("Selected, wait...");
U = 0;
delay(3000);
for(int i = 0; i < 1000000; i++)
// service auto-polling
now = millis();
// HB update
HeartbeatLoop();
// spend all our spare time reading the transducer
swr.Poll();
// auto-polling
if (autoPoll && (Elapsed(now, lastPoll) >= autoPoll)) {
lastPoll = now;
if (autoRaw) {
HostSerial.write(strcpy_P(ioBuffer, PSTR("#RAW=")));
snprintf(ioBuffer, sizeof(ioBuffer), "%d", swr.ForwardRaw());
HostSerial.write(ioBuffer);
HostSerial.write(",");
snprintf(ioBuffer, sizeof(ioBuffer), "%d", swr.ReflectedRaw());
HostSerial.write(";");
if (echo) {
HostSerial.write("\r\n");
HostSerial.write(strcpy_P(ioBuffer, PSTR("#SWR=")));
HostSerial.write(';');
if (echo) {
HostSerial.write(strcpy_P(ioBuffer, PSTR("\r\n")));
// update user displays, bar graphs, etc.
if (Elapsed(now, lastDisplay) > DisplayUpdateInterval) {
UpdateDisplays();
lastDisplay = now;
#endif // ENABLE_DISPLAY == true
// if user input ready
if (inputReady) {
// for each char received from the USB...
for (int i = 0; i != inputString.length(); ++i) {
char ch = inputString.charAt(i);
// if we are in command mode...
if (cmd) {
if (ch == '#') {
// if a '#' sent mid-command, start over
cmdText = "";
} else if (ch == ';') {
// terminate and process the command string
cmd = false;
bool ok = false;
if (echo) HostSerial.print(';');
// parse the command and argument
SplitCommand(cmdText, command, argument);
if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("SWR")))) {
// SWR: read A/D and compute SWR
// add the SWR value to the response
cmdText += "=";
cmdText += ioBuffer;
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("RAW")))) {
// RAW: read A/D and output raw values
cmdText += "=";
cmdText += ",";
ok = true;
} else if (command.equalsIgnoreCase("PWR")) {
// POWER: read A/D and output scaled values
cmdText += "=";
cmdText += ",";
ok = true;
} else if (command.equalsIgnoreCase("ALL")) {
// ALL: read A/D and output scaled values + SWR
cmdText += "=";
cmdText += ",";
cmdText += ",";
ok = true;
} else if (command.equalsIgnoreCase("ECHO")) {
// QUERY/SET ECHO
if (argument.length() == 0) {
ok = true;
cmdText += "=";
cmdText += echo ? "1" : "0";
int newEcho = argument.toInt();
echo = newEcho ? true : false;
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("AUTO")))) {
// QUERY/SET AUTO-POLL
ok = true;
cmdText += "=";
cmdText += autoPoll;
int newAuto = argument.toInt();
if (newAuto >= 0 && newAuto < MaxAutoPoll) {
autoPoll = newAuto;
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("AUTORAW")))) {
// QUERY/SET AUTO-POLL RAW MODE
ok = true;
cmdText += "=";
cmdText += autoRaw ? "1" : "0";
autoRaw = newAuto ? true : false;
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("VERSION")))) {
// QUERY VERSION NUMBER
ok = true;
cmdText += "=";
cmdText += VERSION_STRING;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("ALPHAFWD")))) {
// QUERY/SET ALPHA - FORWARD
ok = true;
cmdText += "=";
cmdText += swr.AlphaForward();
// read the value (float)
for (uint8_t i = 0; i != argument.length(); ++i) {
ioBuffer[i] = argument.charAt(i);
ioBuffer[argument.length()] = 0;
float alpha = atof(ioBuffer);
// set the value
swr.AlphaForward(alpha);
// read-back to see what actually got set
cmdText = command + "=" + swr.AlphaForward();
ok = true;
save_eeprom();
#endif
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("ALPHAREF")))) {
// QUERY/SET ALPHA - REFLECTED
ok = true;
cmdText += "=";
cmdText += swr.AlphaReflected();
// set the value
swr.AlphaReflected(alpha);
cmdText = command + "=" + swr.AlphaReflected();
ok = true;
save_eeprom();
#endif
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("EREAD")))) {
// READ: get startup settings from EEPROM
load_eeprom();
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("EWRITE")))) {
// WRITE: commit settings to EEPROM
save_eeprom();
ok = true;
} else if (command.equalsIgnoreCase(strcpy_P(ioBuffer, PSTR("ECLEAR")))) {
// FACTORY: reset EEPROM data
clear_eeprom();
ok = true;
#endif
// TODO: process other command contents
// respond with #OK or #ERR
if (echo)
HostSerial.print(strcpy_P(ioBuffer, PSTR("\r\n")));
HostSerial.print(ok ? strcpy_P(ioBuffer, PSTR("#OK:")) : strcpy_P(ioBuffer, PSTR("#ERR:")));
HostSerial.print(cmdText);
if (echo)
cmdText = "";
if (cmdText.length() < CommandLength) {
cmdText += ch;
if (echo) {
HostSerial.print(ch);
continue;
// start command mode??
if ((!cmd) && (ch == '#')) {
cmd = true;
if (echo) HostSerial.print('#');
continue;
// clear the string:
inputString = "";
inputReady = false;
// service the serial port
while (HostSerial.available()) {
// get a new byte
char inChar = (char)HostSerial.read();
// add it to the inputString
if (inputString.length() < InputLength)
inputString += inChar;
inputReady = true;
if (D == 1) {
display.clear();
display.print ("NOT AVAILABLE");
D = 0;
// Your code here
if (L == 1) {
display.clear();
analogWrite(3, 0); //Stops the motor
L = 0;
// Your code here
Here is the full code.
The part that reads direction is inside the if statment
IF I edit the code like this
Then it starts refreshing the seccond line on lcd like it should.
Like this everything works like it should. only problem is now that it wont accept any more commands until I reset arduino.
If motor is turning right, direction changed everything is fine. I cannot stop the motor or I cannot make the motor to change direction.
If I remove the "for(int i = 0....." part, then buttons start working agian but direction does not change.
Hopefully my explantion was good enough.
Im pretty new to arduino coding. I know some stuff but not enough.
If someone know how to fix this issue then please edit my original code. with that I can compare two codes and I see what has been changed.
Thank you.
